I successfully read values from my boiler by adding this code to my modbus.config:
- name: modbus_kwb
type: tcp
host: 192.168.11.21
port: 502
sensors:
- name: Heizkreis_Programm
slave: 1
address: 24589
input_type: holding
state_class: measurement
data_type: int16
precision: 1
scale: 1
i successfully managed to show text intstead of integers with a template named select.heizkreis.
it presents the current state correctly with:
{{ [ 'Automatik',
'Frostschutz',
'Aus',
'Komfort',
'Absenk'][states('sensor.heizkreis_programm')|int] }}
it prepares the options of the selection correctly with:
{{ [ 'Automatik',
'Frostschutz',
'Aus',
'Komfort',
'Absenk'] }}
what kind of actions do i need to add to write the selected value (an integer from 0 to 4) into the corresponding modbus register?
petro
(Petro)
April 7, 2026, 3:16pm
2
You’ll be using the modbus write_register actions. You can make a template select entity that does all the work for you.
pyspilf
(Sandro)
April 24, 2026, 8:52am
3
Not sure if this may help in your case, perhaps you can use it as a starting point.
I integrated my heatpump using Modbus, and I set up buttons on a card to increase / reduce the setpoint, invoking a script, like this:
alias: "Heat Pump: Setpoint +1"
mode: single
sequence:
- action: timer.start
entity_id: timer.heat_pump_setpoint_disable
- variables:
curr: "{{ states('sensor.heat_pump_water_temp_zone_1')|int }}"
new: "{{ curr + 1 }}"
- action: modbus.write_register
hub: waveshare_heat_pump
slave: 1
address: 11
value: "{{ new }}"
In my specific implementation I use a timer to disable the button(s) while Modbus updates since I want to avoid multiple commands being sent too fast:
timer:
# Timer to Disable Setpoint Buttons between Modbus Updates
heat_pump_setpoint_disable:
name: "Heat Pump Setpoint Disable"
duration: "00:00:10"
I have a similar script for reducing the setpoint.
This is what it looks like on the dashboard. I have added logic to disable the +/- buttons, make them dim, and display an icon while the timer is active, so it is not possible to press a button more than once for each timer period… I can share the bubble card code I am using should you be interested.
Thank you for your answer. It helped me to find a solution, which is not totally satisfying, but works. As described, I define a sensor in my modbus configuration file modbus.yaml:
- name: modbus_kwb
type: tcp
host: 192.168.11.21
port: 502
sensors:
unique_id: heizkreis_programm
slave: 1
address: 24589
input_type: holding
data_type: int16
This creates sensor.heizkreis_programm and holds integers, which I do not like to handle with.
Following your advice I define a template, which translates the integers to text and creates select.heizkreis_programm_select:
- select:
- name: Heizkreis Programm
unique_id: heizkreis_programm_select
state: "{{ [
'Automatik',
'Frostschutz',
'Aus',
'Komfort',
'Absenk'] [states('sensor.heizkreis_programm')|int] }}"
options: "{{ ['Automatik',
'Frostschutz',
'Aus',
'Komfort',
'Absenk'] }}"
select_option:
hub: modbus_kwb
address: 24589
value: >
{% if option == 'Automatik' %}
0
{% elif option == 'Frostschutz' %}
1
{% elif option == 'Aus' %}
2
{% elif option == 'Komfort' %}
3
{% else %}
4
{% endif %}
Then I make sensor.heizkreis_programm unvisible, because I do not like to see numbers.
What I do not like in this solution:
The code is splitted up into two parts, one in the modbus configuration, the other in the templates configuration.
I code the translations two times, one time from number to text and a second time from text to numbers.
It needs two entities, where a single select would do the job.
I would prefer, if there was an entity select in the modbus integration, which allows to do all this in the modbus config file.
petro
(Petro)
April 27, 2026, 2:49pm
5
- select:
variables:
options:
- Automatik
- Frostschutz
- Aus
- Komfort
- Absenk
state: "{{ options[states('sensor.heizkreis_programm')|int] }}"
options: "{{ options }}"
select_option:
hub: modbus_kwb
address: 24589
value: "{{ options.index(option) }}"
thanks, this helps for more clarity.
