Hi there,
did you ever want to control your Selve-Shutters from HomeAssistant, but you only have a Selve Home Server 2? Well, now you can, and even without the RF-USB Module!
All you need is the Selve Home Server 2 itself and a Matter Hub (Python Matter Server works as well) and you can get started.
Simply follow the instructions on the GitHub and start automating:
https://github.com/SchneiderMaster/selve-matter-bridge
(Note that only Commeo shutters are supported so far because of technical limitations on my end)
Cheers,
SchneiderMaster
