Hi all,
someone know if, and how, it’s possible send 2 mqtt topic/payload using a switch ?
I have 2 switch:
1 - relay1 on/off
2 - ralay2 on/off
I need a switch to turn off both the relay.
Thnaks you
Alessandro
Hi all,
I have 2 switch:
1 - relay1 on/off
2 - ralay2 on/off
Thnaks you
Alessandro
I have 2 relay controls. One is single relay the other is double relay. I control both differently.
switch 4:
- platform: mqtt
state_topic: homie/a020a6125481/light/on
command_topic: homie/a020a6125481/light/on/set
payload_on: 'true'
payload_off: 'false'
optimistic: false
qos: 0
retain: true
And the other one is done using aRest. Relay 2 is the same just different digital pin.
switch 6:
platform: command_line
switches:
arest_pin_two:
command_on: '/usr/bin/curl -X GET http://192.168.20.25/digital/2/0'
command_off: '/usr/bin/curl -X GET http://192.168.20.25/digital/2/1'
friendly_name: Relay 1
my case is different. I have a 2 relay board controlled via mqtt for a windows cover.
Hi have 2 switch, on for open the cover (power on relay1) and the second for close the cover (power on relay2).
I want to add a switch to stop the cover, in this case I should send 2 mqtt topic:
Regards
Alessandro
Could you find a solution i have the same Problem.
Hi @Phoenix,
the first solution is using nodered for relay cntrol, so my mqtt command is for nodered who does all the work.
The last solution is the interlock function added to the firmware, I use Electodragon relay board,
