Send a command to Tasker
Hi, Does anyone know of the best way that using a Notification from Home-Assistant that a command can be sent to an Android Device running Tasker.
I don’t want messages to rely on an external 3rd party service so things like AutoRemote and Join wouldn’t fit the bill.
I did find a MQTT Client for Android that has Tasker, but it needs Android 4.4. The device I am running is 4.2 and I’ve had problems trying to upgrade it in the past.
I also found a UDP Listener for Android that has Tasker, but I’am not sure what to use on Home Assistant other than the Command Line Notifier and write a script.
Any ideas?
Update
I spoke with the creator of the MQTT Client (Tasker Plugin) Android app and he has updated it so that it worsk with Jellybean 4.2.2. Just finished testing and I can now send a MQTT message to my Android tablet and get Tasker to act upon it.
e.g. I can send some text that Tasker then says it with Androids built in TTS
I tried the Mqtt client service to switch on/off the webcam with Tasker and cloudmqtt but it worked only when the apps were just started. In standby it did not work properly. I am also interested I’m alternatives! :slight_smile:
I had a similar problem initially when getting the Light Sensor on Android to update a MQTT sensor on Home-Assistant. On Tasker, try setting the ‘Net/Cell Wake Screen’ setting as a work around.
I know this is an old thread but it would be really handy if you could share your configuration for HA, MQTT Client and Tasker I would like to do exactly the same thing.
I am using a plugin called AutoRemote to send my alarmclock status and time to Tasker.
In the Plugin I created a new IFTTT device and instead of entering my IFTTT key I just typed hass as my secret key. And named the new device HomeAssistant.
You’ll get an URL that looks like:
https://autoremotejoaomgcd.appspot.com/sendmessage?key=API&sender=hass&message=MESSAGE_HERE
The API is an unique string from AutoRemote. I put the API string and the sender in my case hass in my secrets,yaml file.
Then I made an shell_command:
tasker_alarm: 'curl -X GET https://autoremotejoaomgcd.appspot.com/sendmessage?key={{ key }}&sender={{ sender }}&message=Alarm=:=Status={{ status }},Time={{ states.sensor.alarm_clock_time.state }}'
In my automations I use:
    - service: shell_command.tasker_alarm
        key: !secret tasker_key
        sender: !secret tasker_sender
        status: "ON"
to send the command to tasker. In Tasker I have an trigger that uses the AutoRemote plugin with an regex filter: Alarm=:=*
The part before =:= is used as a filter in tasker and the part after it is available in the task.
This is good, I will use this to communicate with tasker (instead of using the notify.html5 component)
Do we need to add the tasker_key and sender_key to every automation / script? Is there a way to use !secret inside the configuration file instead?
tasker_alarm: 'curl -X GET https://autoremotejoaomgcd.appspot.com/sendmessage?key= !secret tasker_key &sender= !secret_tasker_sender &message= {{ arprr } =:= {{ arcomm }}'
    arprr: "test"
    arcomm: "test"
