Yes, that’s a use for the condition attribute.
That’s perfect. Now I’m wondering if I can have two conditions? The Quiet Time and the example from above, media player idle? Do I separate those with a comma?
You can do something like this:
{{ is_state('mediaplayer.mymedia','idle') and is_state('binary_sensor.quiet_time','off') }}
Alright! thanks
Change the service google tts to this
- service: notify.alexa_media
type: tts
- !input 'target'
message: "{%- set single_lst = single_msg.split('\\n') -%}\n{%- set multiple_lst\
\ = multiple_msg.split('\\n') -%}\n{%- if persons_count|length > 1 -%}\n {{\
\ multiple_lst | random | replace('<persons>', persons_names) }}\n{%- elif persons_count|length\
\ > 0 -%}\n {{ single_lst | random | replace('<person>', persons_names) }}\n\
{%- endif -%}\n"
How can i add a delay ?
Do you want to add a delay before the greetings?
Yes, but set a break time with Amazon Polly
Tried this but Alexa doesn’t talk. What could I be doing wrong?
Yes, I would like to know that too. How to add a delay before the greeting? TKS
Can you explain in more detail what “Minutes between person at home and door trigged” means? If I set the time to 10 min for example.
Is it also possible to add so that it is not activated between 19:00 and 08:00?
Hey i saw this blueprint and wanted to test it.
I edited a little bit and added a delay and mine works with alexa.
Here is the code:
blueprint:
name: TTS on door opening with persons at home with Alexa
description: Sends TTS message to a media_player when door is oppened with the person
at home
domain: automation
input:
door_sensor:
selector:
entity:
domain: binary_sensor
device_class: door
persons:
selector:
entity:
domain: person
minutes:
description: Minutes between person at home and door trigged
default: 5
selector:
number:
min: 1.0
max: 30.0
step: 1.0
unit_of_measurement: min
mode: slider
message-single:
name: Message single person
description: 'Message to salute single person. One possible message per line.
Use <person> tag to be replaced by person name.
selector:
text:
multiline: true
message-multiple:
name: Message multiple persons
description: 'Message multiple persons. One possible message per line. Use <persons>
selector:
text:
multiline: true
persons-concat:
name: Text to concatenate the persons name
description: String to be used as concatenate between names
default: ' and '
selector:
text:
multiline: false
delay:
name: delay of TTS
description: Delay between door opening and TTS
default: 3
selector:
number:
min: 0.0
max: 30.0
step: 1.0
unit_of_measurement: sec
mode: slider
description: Target devices to play the TTS message
selector:
entity:
domain: media_player
condition:
name: Condition to run
description: Add a value_template value for major condition to execute the automation
default: 'True'
selector:
text: {}
actions:
description: After the execution of the automation, run those actions.
default: []
selector:
action: {}
source_url: https://gist.github.com/rokam/22fd6e497fbe61478fda4d0fc8215abf
variables:
persons_str: !input 'persons'
persons_list: '{{ persons_str.split('','') | map(''trim'') | list }}'
timeout: !input 'minutes'
concat_str: !input 'persons-concat'
addactions: !input 'actions'
persons_count: "{%- set first = true -%} {%- set data = namespace(nomes=[]) -%}\
\ {%- for person in persons_list -%}\n {%- if is_state(person, 'home') and (now()\
\ - states[person].last_changed).total_seconds() < timeout*60 -%}\n {%- set\
\ data.nomes = data.nomes + [states[person].name] -%}\n {%- endif -%}\n{%- endfor\
\ -%} {{ data.nomes }}\n"
persons_names: '{%- set finalstr = '', ''.join(persons_count) -%} {{ concat_str.join(finalstr.rsplit('',
'',1)) }}
single_msg: !input 'message-single'
multiple_msg: !input 'message-multiple'
- platform: state
entity_id: !input 'door_sensor'
to: 'on'
- condition: template
value_template: !input 'condition'
value_template: '{{ persons_count|length > 0 }}'
- delay: !input 'delay'
data_template:
target: !input 'target'
type: tts
{%- endif -%}\n"
value_template: '{{ addactions|length > 0 }}'
- choose: []
default: !input 'actions'
mode: single
The timeout shoud end when the door Open, if you Open the door again say hello again.
wait_for_trigger ?? Can this be done?
Why is it splitting the lines this way?
Can’t it be done with just the \n
? My list does not work properly, I have to add double line separations for this to work.
This looks really cool. One suggestion @rokam , would it be possible for the greeting to include a list of the people that were already home before?
"Welcome back <person>, <other_person_1> and <other_person_2> are currently at home."
That means that people that have the state changed in the last 10 minutes will be greeted.
Yes, you can use the condition_to_run. I do have an input_boolean that corresponds to my night_mode and I set it with another automation. I use the following condition value.
{{ is_state('input_boolean.night_mode','off') }}
Where is that? The GUI for the automation? I already tried that, but homeassistant doesn’t seem to like it and does nasty things when it saves the automation.
