Hay all.
Trying to send 3 pieces of data in the same mqtt message and hitting brick walls with what I assume should be a simple task. Simply need to send 3 numbers and retrieve them at other end but not getting anywhere. Is it possible?
Hay all.
Can’t you send them as json?
Yep that seems to work I think. I was trying that but had the format incorrect. Thanks for that
