Send Message to Bot based on time
Hi.
I am pretty new with HA. I have managed to intergrate Telegram Bot.
I want to do a very simple thing (well in my mind)
I want to check a status of a device, which is fairly easy but i then want to Send a message to my Telegram bot at like say 8AM
I have looked at the time intergration and other things but i was wondering if there was just a very simple way of achieving it.
An example of what i am trying to do.
Get Home Assistant to check a Zigbee device is online (lame but i am just messing around at the moment), then send a message to my bot at 8AM.
LIke i said i have the telegram bot working for my other automations, its just the timing section for my message to be sent i am struggling with.
thanks
Welcome to the loony bin! :slight_smile:
At what time do you want the state checked? If it doesn’t matter, just check it at 08:00 and then send the message. This is easy.
If you want the state check and the message at different times, that will be a little more work. :slight_smile: You’d need to explain more, especially when your check should be performed. :slight_smile:
thanks for replying
it can be the same time, in fact if that is easier, thats fine.
I was more struggling on how to write the code for it, tried using the GUI automation but cannot seem to find what i am looking with regards.
You have to setup a notifier like this:
notify:
  - platform: telegram
    chat_id: CHAT_ID_1
After that you setup an automation like this:
automation:
  - id: 'My telegram notification'
      - platform: time
        at: '08:00:00'
    condition:
      - condition: state
        entity_id: sensor.myzigbeedevice
        state: 'on'
      - service: notify.NOTIFIER_NAME
          title: "*Send a message*"
          message: "Super cool message here"
As trigger and condition you can use one of these: Automation Trigger - Home Assistant
This does the following: At 08:00 it starts running, checks, if the device is on, if not it ends, if it is on, it will send the message.
EDIT: Somehow some of my text got lost, I added it back again.
thats is perfect mate, thank you for taking time to show me that.
Don’t forget to mark paddy0174’s post with the Solution tag. Only you, the author of this topic, can do that. It will automatically place a check-mark next to the topic’s title which signals to other users that this topic is resolved. It makes it easier for users to find answers to similar questions.
