hagenuck1
(Hagenuck1)
January 4, 2019, 10:56am
1
Hi there,
Im trying to get an automation working to send the state of an input_number as a list.
In my case im using a Xiaomi vacuum and trying to set the volume, which needs to be send as „params: [40]“ for example, the values need to be a list!
When I’m trying to send a fix value it works, but as soon as I insert a variable here it seems to be send as a string instead a list, which isn’t recognized by the vacuum.
Working fix values:
- service: vacuum.send_command
data_template:
entity_id: vacuum.roborock
command: change_sound_volume
params: [40]
Not working state values (Being send as string):
data_template:
params: "[{{ states('input_number.vacuum_volume') | int }}]"
If I don’t insert the quotes I get the attached error:
data_template:
Error:
Error loading /config/configuration.yaml: invalid key: “OrderedDict([(“states(‘input_number.vacuum_volume’) | int”, None)])”
in “/config/automation/automations.yaml”, line 308, column 0
For testing pruposes I inserted a push to my device to see what values are given, which looks fine (it’s still a string, so I can’t see the issue here):
- service: notify.ios_device
message: "[{{ states('input_number.vacuum_volume') | int }}]"
Is there a hint why this isn’t working or does anybody has a solution?
Greets
petro
(Petro)
January 4, 2019, 1:13pm
2
Try:
data_template:
params: "{{ [ states('input_number.vacuum_volume') | int ] }}"
hagenuck1
(Hagenuck1)
January 4, 2019, 2:35pm
3
Thanks, tried that yesterday, already. But the robot doesn’t change the volume.
I guess there’s no way to check what data (and datatypes) are given to the send_command, right?
petro
(Petro)
January 4, 2019, 3:30pm
4
Alright, then this one should work:
data_template:
params:
- "{{ states('input_number.vacuum_volume') | int }}"
This keeps params as a list and you are templating the first item.
EDIT: This should also work:
data_template:
params: [ "{{ states('input_number.vacuum_volume') | int }}" ]
petro
(Petro)
January 4, 2019, 3:33pm
5
Jinja only outputs strings. So the data type is always a string, which I suspect is the underlying problem. So we need to provide a way to enforce that it is a list of items. Jinja will naturally convert the strings to numbers if they can but it will not convert a string to a complex type like a list.
hagenuck1
(Hagenuck1)
January 4, 2019, 4:59pm
6
Thanks for these ideas, but unfortunately none of them works
Even this one isn’t Working:
data_template:
params: ["{{ 1 + 1 }}"]
But it seems to calculate right, because if I insert this in my test notifications I get [2] as notification:
message: "[{{1 + 1}}]"
The Params for the vacuum seems not to be a string, because if I insert
message: [ "{{ states('input_number.vacuum_volume') | int }}" ]
I get this expected issue in my log:
voluptuous.error.MultipleInvalid: template value should be a string for dictionary value @ data['message']
petro
(Petro)
January 4, 2019, 5:51pm
7
Thats because message does not accept a list.
do not mix this up between templates. params may accept a list where message does not. Message will only accept a single string.
Did you try:
data_template:
params:
hagenuck1
(Hagenuck1)
January 4, 2019, 6:10pm
8
Yes I only did this to check if the output is a list instead a string.
Yes that one didn’t work, too.
petro
(Petro)
January 4, 2019, 6:16pm
9
did you get an error with that last one?
hagenuck1
(Hagenuck1)
January 4, 2019, 6:39pm
10
No, it’s the same as with all other tries the robot just doesn’t change its volume.
petro
(Petro)
January 4, 2019, 7:28pm
11
Well i just noticed there’s an extra space on each line after the service line. Try it again with this.
data_template:
params:
hagenuck1
(Hagenuck1)
January 4, 2019, 11:55pm
12
Thanks, I removed that space when pasting in Home assistant already, because I guessed I copied to much. So this error still exists.
To test if these could work I tried the following:
data_template:
params:
- 10
Which isn’t working, too. (Doesn’t change the volume)
petro
(Petro)
January 5, 2019, 12:54am
13
not sure if it’s a copy error, but it looks like service and data_template are not in the same line.
