Hello to all,
I am trying to send mqtt data from a different wifi point than the one where my home asistant server is located.
I managed to do it a while ago without SSl (no security).
Which is very dangerous nowadays, so I am trying to do it by certificates.
I have the router port 443 open and I use for the HTTPS of the home assitant 8123.
In principle I have configured the mqtt plugin for 443 and localhost, but it doesn’t let me activate the auto authentication.
So if it doesn’t connect to the arduino I think it has to do with the certificates.
I leave you the arduino code, and if someone can give me the steps to follow I would appreciate it.
Arduino code:
#include <esp_crt_bundle.h>
#include <ssl_client.h>
#include <WiFiClientSecure.h>
#include <ArduinoJson.h>
#include <WiFi.h>
#include <PubSubClient.h>
#include <DHT.h>
// WiFi network name and password:
const char* ssid = "xxxxxx";
const char* password = "xxxxxx";
// MQTT Broker settings:
const char* mqtt_server = "xxxx.duckdns.org";
const int mqtt_port = 443;
const char* mqtt_user = "mqtt";
const char* mqtt_password = "xxxxxx";
// Certificado CA raíz en formato PEM:
const char* root_ca= \
"-----BEGIN CERTIFICATE-----\n" \
"-----END CERTIFICATE-----";
// Configuración del sensor DHT11
#define DHTPIN 33 // Pin donde está conectado el DHT11
#define DHTTYPE DHT11 // Tipo de DHT
DHT dht(DHTPIN, DHTTYPE);
WiFiClientSecure espClient;
PubSubClient client(espClient);
void setup() {
Serial.begin(115200);
dht.begin();
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println("WiFi conectado");
// Configurar el cliente MQTT
espClient.setCACert(root_ca); // Establecer el certificado CA raíz
client.setServer(mqtt_server, mqtt_port);
client.setClient(espClient);
client.setCallback(mqtt_callback);
void loop() {
if (!client.connected()) {
mqtt_reconnect();
client.loop();
// Leer datos del DHT11
float humidity = dht.readHumidity();
float temperature = dht.readTemperature();
// Verificar si alguna lectura falló y salir temprano (para intentar de nuevo).
if (isnan(humidity) || isnan(temperature)) {
Serial.println("¡Fallo al leer del DHT!");
return;
// Crear el objeto JSON para los valores de temperatura y humedad
StaticJsonDocument<200> jsonDoc;
jsonDoc["temp"] = temperature;
jsonDoc["hum"] = humidity;
char jsonBuffer[512];
serializeJson(jsonDoc, jsonBuffer); // Serializar el objeto JSON a una cadena
// Publicar los valores al broker MQTT
client.publish("esp32iotsensor/CustomSensor", jsonBuffer);
void mqtt_callback(char* topic, byte* payload, unsigned int length) {
// Manejar mensaje recibido
void mqtt_reconnect() {
// Loop until we're reconnected
while (!client.connected()) {
Serial.print("Intentando conexión MQTT...");
// Attempt to connect
if (client.connect("ESP32Client", mqtt_user, mqtt_password)) {
Serial.println("conectado");
// Subscribe or publish here
} else {
Serial.print("falló con estado ");
Serial.print(client.state());
delay(5000);
