Context
I want to create an N8N automation which will fire whenever a webhook automation is triggered.
This may seem like a very esoteric use case, but is in fact not so inconceivable!
In my case, I want to implement an automation that:
- Triggers when a home assistant plugin turns active.
- Runs a prompt through a large language model
- Sends a templated email notification which seems to be a little challenging to do nicely in the built-in automations.
The Workaround
Currently the lack of a webhook action has to be worked around by manually adding rest commands into configuration.yaml
Once done, they are exposed as RESTful commands that can be called as actions in automations, like this:
However, this approach is significantly more limited than the functionality on the other side, that of triggering webhooks.
It would be nice to be able to do all these common actions via the UI:
- Change webhook URL
- Change REST command type
- Rename webhook (etc)
Webhooks are supported natively on the other side of the automation chain as trigger events:
So to enable users to make full use of this popular and powerful home automation stack (N8N + HA) it would be nice to have full native support for both trigger and sending webhooks
