Sensereo joins Works with Home Assistant
We’re sensing a change in the air this month as we welcome Sensereo to the Works with Home Assistant program 🎉. Specialists in environmental sensing, Sensereo brings Matter smoke and carbon monoxide (CO) alarms into the Home Assistant ecosystem – meaning more ways to keep your home open, safe, and sound.
Built from a burning question…
What happens if your smoke alarm goes off, but you’re not there to hear it? It’s an unsettling question, and one that led Roy Chen to found Sensereo in 2024. Driven to create safety devices that were equal parts reliable and resilient, Sensereo built the Matter-based MS-1 Smoke Alarm and MSC-1 Smoke and Carbon Monoxide Alarm, because as they put it: “every home deserves a system that will not fall silent when it matters most.”
It’s just good sense
For anyone unfamiliar, Matter is an open standard that lets smart home devices from different brands work together, regardless of who made them – no lock-in, no closed ecosystems. It’s exactly the kind of open, interoperable technology the Open Home Foundation exists to champion. Thread operates on the same principle: it’s an energy-efficient, wireless mesh network that connects devices directly to one another and can automatically reroute around disruptions. And for battery-powered alarms like Sensereo’s, Thread’s low-power design means fewer battery changes for devices that are always on duty.
While we’re talking about safety, it’s important to note that if your Thread network did for any reason drop out, Sensereo’s smoke and CO alarms will keep working as a “regular” alarm would – no smart home required.
That peace of mind is central to how Sensereo thinks about their products, and having caught up with the team at CES 2026 earlier this year, we can tell you it’s just the beginning. Air quality sensors and more are on the horizon, all building toward the same vision: to build an environmental intelligence system for the home that helps users understand and respond to their surroundings.
"Joining the Home Assistant ecosystem is a natural step for us, as it enables an open and user-driven platform where these capabilities can truly come together. We're excited to contribute not only our current fire safety products, but also future sensing devices that expand how people interact with and manage their living spaces."
- Roy Chen, Sensereo Founder
Devices
Most of us want our smoke alarms to be “reasonably annoying”, and Sensereo clearly agrees, because they printed this very description on the MS-1’s packaging. Which, as we love to see, has been designed sustainably – signaling the company’s commitment to one of the Open Home Foundation’s three core principles before you’ve even opened the box.
Sensereo MSC-1 smoke and carbon monoxide detector
The MSC-1 goes a step further with a nifty, built-in digital display showing real-time carbon monoxide levels. Since CO is odorless and invisible, being able to accurately check levels at a glance lets you know if there is a rise and act before it becomes an emergency – not just after an alarm sounds.
And with local integration, that kind of proactive awareness extends further still – allowing you to build around the people in your home, not just the devices. A smoke detection event could flash smart bulbs for a family member who’s hard of hearing, or send a separate alert to a caregiver. Your alarm does its job – and so does everything else around it. It’s this kind of thoughtful design that shows us Sensereo are here for all the right reasons.
Like all partners of the Works with Home Assistant program, Sensereo commits to providing long-term support and firmware updates, as well as staying connected to the community they’re helping protect 💪. As always, the MS-1 and MSC-1 have been rigorously tested and certified by our in-house team to meet our core requirements of local control, privacy, and long-term sustainability. The program’s operated by the Open Home Foundation, which is funded with the support of Home Assistant Cloud subscribers. With each new partner like Sensereo that expands the program, we’re able to give more choice, support, and peace of mind to Home Assistant users.
Breathe easy
No smoke and mirrors – just reliable home safety devices and a team that clearly gets what this community is about. Sensereo’s commitment to building open, locally controlled tech is exactly what we love to see in the Works with Home Assistant program, and why we’re so thrilled to have them on board. Check out our certified device list to see what else is there!
FAQs
Q: If I have a device that is not listed under “Works with Home Assistant” does this mean it’s not supported?
A: No! It just means that it hasn’t gone through a testing schedule with our team or doesn’t fit the requirements of the program. It might function perfectly well but be added to the testing schedule later down the road, or it might work under a different connectivity type that we don’t currently test under the program.
Q: OK, so what’s the point of the Works with program?
A: It highlights the devices we know work well with Home Assistant and the brands that make a long-term commitment to keeping support for these devices going. The certification agreement specifies that the devices must have the functionality you would expect within Home Assistant, operate locally without the need for cloud and that they will continue to do so long-term.
Q: How were these devices tested?
A: All devices in this list were tested using a standard Home Assistant Green Hub with the Home Assistant Connect ZBT-2 as the Thread Border Router and with our certified Matter integration. If you have another hub / border router set-up / integration that’s not a problem but we test against these as they are the most effective way for our team to certify within our ecosystem.
Q: Will you be adding more Sensereo devices to the program?
A: Why not! We’re thrilled to foster a close relationship with the team at Sensereo to work together on any upcoming releases or add in further products that are not yet listed here.
This is a companion discussion topic for the original entry at https://www.home-assistant.io/blog/2026/05/28/sensereo-joins-works-with-home-assistant
Nice! However spotted WWHA certification page says "worldwide" but wondering if these models or future models will actually be CE-certified for the EU and sold in European Union as well?
Plus pages does not make it clear if where their warehouses are and shipping is done from, both of which should be specificed so do not have to pay unexpected import taxes and/or custom fees.
Also noted that their webpages lists compability with Apple Home, Homey, SmartThings, and Google Home, but does not yet mention WWHA or have any Works with Home Assistant badges.
PS: Think "sealed battery for 7-years" can be a dealbreaker in some countries if laws require it to work 10-years if using sealed batteries instead of replacable or mains-powered + rechangable.
The typical life expectancy of a CO sensor is 5 to 10 years. I'd rather not have a manufacturer push the limit and risk failure because the governments rather wants things to last longer.
From their homepage:
From the FAQ in the product page you linked to:
Agreed regarding the missing shipping info though.
These look great, but can someone make a hardwired version of something like this? Law here requires hardwired on all new builds. And then seems silly to rip out hardwired system to replace with a smarter, but battery-powered, system.
I have sent a query regading these meeting AS 3786 as it would be great to have these available to be used in Australia. Like others have requested, some states in Australia require hardwired as well so this shoud be explored by Sensero.
This sounds great. I need one that is certified for the US and is hardwired along with battery as my local building codes require it! The only "smart" detector I've found around here is from Kidde and well, it sucks. Plus their latest models require a Ring account which I refuse to get.
Until they produce smoke alarms that meet UL 217 and can be hardwired this is awesome but a nonstarter for US folks. They say they're working on it which is great, I hope that comes sooner rather than later.
I am guessing that WWHA only validates functionality with HA, but it would be nice for the program to insist that the status of compliance with safety certifications be clear on the company's site, and to mention standards in the WWHA announcments. The situation as uncovered here is that this is a European product -- which is great for lots of people, and totally reasonable. But when I saw the announcement I immediately wondered about US use.
I'm pretty sure that using a non-listed smoke detector in the US is ok. What's not ok is removing or not maintaining the listed products. So if you have detectors installed that meet code, and then you add these, that's fine.
I'm sure Sensereo understands this, but in addition to code varying by US state, the requirements for smoke alarms vary by the date of construction or substantial renovation. Recent construction tends to require hardwired power with battery backup, and also interconnection such that if one alarm detects they all sound.
I also have the impression that CO detectors are prohibited from displaying sub-threshold levels. I don't like that as I want to see values, but if it ends up being possible to report those values to HA while not displaying them, that would be 99% as good. I want to get a not-yet-alarm notification that values are out of normal.
I have bought three of these (MS-1). My HA is running HAOS, OTBR, SkyConnect and Matter server. I have not yet been able to adopt the devices to my thread network.
Tried resetting Android Play-store cache, using another phone etc.
Does anyone know if this is supposed to work?
I have the same issue, I tried with my iphone and also an Android tablet as I found somewhere that there might be issues with IOS. I checked my network that it has internally ipv6 enabled but still I get nowhere. With the Thread app on Android i can see that my Thread network is operational but it won't connect. I have other Matter devices that are working fine but these just won't connect.
After my post earlier I was able to resolve my issue. The issue in my case must have been my unifi network. So here some tips that resolved my problem:
  • Make sure mDNS is enabled
  • make sure your IOT network is IPv6 enabled
  • use android devices to add Thread devicesas IOS is not working.
After these changes I was able to add 4 devices.
I just bought 10 Kidde CO/Smoke detectors :frowning:
Would have loved to buy Sensereos, but hardwired was a requirement for me
I have a MS-1 and MSC-1 both working via SkyConnect (ZBT-2) on HAOS.
Might be good to ask further in
Hi Hedda,
Thanks a lot for your detailed feedback and suggestions. I'm a test engineer at Sensereo , and I'd like to clarify a few points.
  1. EU certification
Our current MS-1 and MSC-1 have obtained the relevant EU certifications for smoke alarms and smoke & carbon monoxide alarms, respectively, and are intended for the European market.
  1. Shipping and import fees
Currently, the shipping cost shown at checkout is an all-inclusive door-to-door delivery fee . Under normal circumstances, customers should not need to pay additional shipping charges after placing an order. Thank you for pointing out that this isn't very clear on our website. We'll look into making this information more explicit to avoid confusion.
  1. Works with Home Assistant
We've now added the Works with Home Assistant badge to our website. If you've visited our product pages before, you may need to refresh the page or clear your browser cache for it to appear.
  1. Battery lifetime
Thank you for bringing up the battery lifetime requirement. We'll certainly take this into consideration for future product improvements. We've also noticed that in some countries, the 10-year battery requirement primarily applies to traditional standalone smoke alarms, while smart smoke alarms may be subject to different requirements depending on local regulations. We'll continue to monitor these requirements as we develop future products.
Thanks again for taking the time to share your feedback. Suggestions like these are very valuable to us as we continue improving both our products and the overall user experience.
Hi ShadowFist,
I'm a test engineer at Sensereo. Thanks for pointing this out.
You're absolutely right that the shipping information could be presented more clearly on our website. Currently, the shipping cost shown at checkout is an all-inclusive door-to-door delivery fee, so customers should not be charged any additional shipping or import fees after placing an order.
We really appreciate the suggestion, and we'll work on making this clearer on our product pages to avoid any confusion for future customers.
Hi Nick,
I'm a test engineer at Sensereo. Thanks for your feedback.
We completely understand your point. In many regions, especially for new builds, hardwired smoke alarms are required by local building codes, so replacing an existing hardwired system with a battery-powered one isn't always a practical option.
We've heard similar feedback from other users as well, and we'll definitely share it with our product and R&D teams. A hardwired version is something we'll take into consideration as part of our future product planning.
Thanks again for taking the time to share your thoughts—we really appreciate the feedback.
Hi Andrew,
I’m a test engineer at Sensereo. Thanks for sharing your thoughts.
We completely understand why a UL-certified hardwired model with battery backup is important for many users in the US, especially where it’s required by local building codes.
We’ve received similar feedback from several members of the community, and we’ll definitely share it with our product and R&D teams. It’s something we’ll take into consideration as we plan future products.
Thanks again for your support and for taking the time to let us know what you’d like to see. Feedback like this really helps us prioritize future development.
Regarding the MSC-1 Matter-Thread Smoke & CO Alarm | Sensereo, why are new devices still developed as 2-in1?
Isn’t it well known that CO sensors require different positioning than Smoke sensors and because of that, combined devices underperform on both ?
Not even sure how they would pass certification because of that.
Maybe this is no longer the case due to modernization of technology , but physics on gasses surely haven’t changed?
I’ve always carefully positioned single job devices ( Co at the wall at optimal height, smoke sensors at the ceiling at optimal distance… can’t be combined.)
Hi Peter,
I’m a test engineer at Sensereo. Thank you for coming back and sharing the solution with the community.
I’m really glad to hear you were able to get all four devices commissioned successfully. It’s also very helpful to know that, in your case, the issue turned out to be related to the network configuration rather than the devices themselves.
Thanks as well for sharing the troubleshooting steps that worked for you:
  • Enabling mDNS
  • Making sure the IoT network has IPv6 enabled
  • Using an Android device for commissioning in your setup
I’m sure this information will be valuable for other Home Assistant users with a similar HA + OTBR + UniFi environment.
We’ll also share your feedback with our engineering team as a real-world use case so we can continue improving the commissioning experience and our documentation.
Thanks again for taking the time to update the thread—we really appreciate it!
