Sensi thermostat will not go below 66 degrees
I have a routine to set my heat to 65 degrees when I’m away from home. This used to work fine until recently. I can’t set the thermostat below 66 degrees from HA. However, I can use the Sensi app to change it to 65 or lower. I believe a recent update may have caused this to break.
Did you see today’s update?
Yep. Looks good!
