Sensibo Climate React only toggles
Trying to create an automation where Climate React turns off or on depending on a presence group state. The presence group I have works perfectly fine. However, when I add the Climate react to it, I would typically want to turn it off or on, however, the function switch on only does a toggle for the Climate React and does not actually turn it on specifically. If I send the command a 2nd time it will turn the Climate React off. Therefore makes the Climate React actually forms out of sync with what is in reality.
Yes - same issue with me.
I see on Github is was fixed last week - so hopefully in the next release?
