Sensibo integration stopped working; now won't accept my API key
Hi all,
I’ve been running the sensibo integration for years; a few weeks ago it simply stopped working.
I deleted the integration and reapplied the API key but to no avail. It refuses to accept it.
I’ve also created new keys; I’ve deleted every key and created just one, I’ve tried it from the cloud address and the local address, from the MacOS app, web page on MacOS Safari and Chrome, iOS app, web page on iOS.
I don’t think my external IP is blocked because the sensibo app and the website work.
I’m at a loss. I’m sure there’s a simple fix.
Hello Glenn E Farrell,
If you are running a DNS blocker like pihole, that may be causing a problem. Also the external access of your browser is not the same as Home Assistant. That’s controlled by setting up and external_url used by cloud services like that one.
I’m having the same issue, nothing has changed in years, no longer accepting the API key. I even created a new key, still wont except.
Same issue here. It is interesting that someone mentioned DNS as this happened around the same time I had issues with PiHole when upgrading to v6. Although I now have disabled my pihole, the issues with Sensibo remain.
Same issue here, tried the same fixes with same results and I do not run pihole
Seeing this same issue over here on the latest version of HA. Sounds like we’ll need to reach out to the maintainer of the integration and see what’s up.
  • Core - 2025.6.1
  • Supervisor - 2025.05.5
  • Operating System - 15.2
Saw this on an unrelated thread, but check whether you have stored Application Credentials for Sensibo in the Settings > Devices & Services > 3 dot menu (top right)
If you do, delete them, restart HA for good measure, then apply the new API keys. Hopefully that’ll fix it.
