My code work fine, but if my sensor is already close at boot, I got no message, I need to open the sensor circuit and close it to get the code to work again
binary_sensor:
- platform: gpio
pin:
number: 12
mode:
input: true
pullup: true
name: "Sump Pump Water Sensor"
device_class: moisture
filters:
- invert:
- delayed_on: 1s
on_press:
then:
- mqtt.publish:
topic: "HassSumpump8266"
payload: "Il y a de l'eau à la SumPump"
retain: true
- while:
condition:
binary_sensor.is_on: sump_pump_water_sensor
then:
- delay: 3s
- mqtt.publish:
payload: "il y a toujours de l'eau à la SumPump"
retain: true
