Sensor average template for dynamic list of entities
Hi, I currently have 8 entities in my lounge that report temperature, for which I’ve templated the following:
{% set room_sensors = states.sensor |
  selectattr('entity_id', 'in', area_entities('lounge')) |
  selectattr('attributes.device_class', 'eq', 'temperature') |
  rejectattr('entity_id', 'is_hidden_entity') |
  rejectattr('attributes.is_group', 'eq', true) |
  rejectattr('attributes.entity_id', 'defined') |
list %}
{% for s in room_sensors %}
  {{ s.state }}
{% endfor %}
which produces this:
11.25
  13
  14
  13
  14
  11.47
  11.2
  11
What I’m trying to get is a template sensor showing the average from all of the sensors but also allows adding or removing sensors without having to edit the template.
I’m currently using a template sensor that lists each entity by entity_id but as I move the sensors around frequently it means a lot of changing the code.
I’ve searched for a couple of hours and found nothing that helps and I’ve gone as far as my knowledge allows. Can anyone suggest how it can be done please?
Thanks, Matt
{{ states.sensor |
  map(attribute='state') |
  map('float', 0) | average(0) }}
Wow, that was super quick…you obviously know your stuff! Thank you so much, it works perfectly.
