Sensor based on different states
Who can help me?
I would like to show in a custom button whether my children are present. For this I have several images which I can then call with a value.
To be able to do this I want to make a sensor that creates different states so that I can call the images with it.
The idea is as follows:
Child A: device_tracker_kind_a
Child B: device_tracker_kind_b
Child C: device_tracker_kind_c
When child A is at home and child b and c are not, the sensor must give the state a-home, when child b is at home b-home and child c c-home, in addition also the following combinations: when child a and b are at home must be deliver the sensor ab-home etc etc
Is this the right way to do this or is there another way?
Example of the Custom Button:
            - type: custom:button-card
              entity: sensor to be created
              show_entity_picture: true
              show_name: false
              show_state: true
              state:
                - value: a-home
                  entity_picture: /local/a-home.png
                - value: b_home
                  entity_picture: /local/b-home.png
Regards, Marius
What about using the first letter (or first 2 letters) of their names…
template:
  - sensor:
      - name: "Which kids are home"
        state: >
          {% set ns = namespace(values='') %}
          {% for e in expand('person.alex', 'person.blair', 'person.cassidy') %}
          {% if e.state == 'home' %}
            {% set ns.values = ns.values + (e.name)[0] | lower %}
          {% endif %}
          {% endfor %}
          {{iif(ns.values != '', ns.values,'not')}}-home
Drew,
this is perfect, what do I need to change for the first 3 letter, my 2 daughters are lin and lil so the first or first 2 letters wont do the job :wink:
You need to expand the slice by changing [0] to [0:3]:
template:
  - sensor:
        state: >
            {% set ns.values = ns.values + (e.name)[0:3] | lower %}
          {% endif %}
          {% endfor %}
Keep in mind when you set up your card, the values will follow the order you have them in the expand(). In the example above the possible values will be:
ale-home
alebla-home
aleblacas-home
bla-home
blacas-home
cas-home
not-home
I’m pretty sure you could do this directly in the card, but it’s been a while since I messed with the type of templating that custom-button-card uses, so I’ll leave that for someone else with more experience…
You are a hero !!! It works like a charm !!! thank you very much !
Not sure if this is something on the order of what you’re looking for, but this is what I do with our family presence:
In my ui-lovelace. yaml file:
button_card_templates: !include lovelace-templates-button-card.yaml
# other non-related stuff
              - entity: sensor.family_sensor
                template: presence-tile-compact
                type: 'custom:button-card'
                variables:
                  m1_entity: device_tracker.sm_n986u
                  m1_name: R
                  m2_entity: device_tracker.janettes_phone
                  m2_name: J
                  m3_entity: device_tracker.kates_phone
                  m3_name: K
The “family sensor” is in a /config/sensors.yaml file as follows:
  sensors:
    family_sensor:
      value_template: >-
        {% set items = states.person %}
        {% set all = items|length %}
        {% set home = items|map(attribute="state")|select("equalto","home")|list|length %}
        {{ "none home" if home == 0 else "all home" if home == all else "some home" }}
      icon_template: >-
        {% if is_state('family_sensor', 'none') %}
          mdi:home-circle-outline
        {% else %}
          mdi:home-circle
        {% endif %}
and the “presence-tile-compact” template is in my lovelace-templates-button-card.yaml file as follows: (with the other definitions I need as well)
  standard:
    color_type: card
    hold_action:
      action: more-info
    styles:
      card:
        - padding: 0.2em
        - '--mdc-ripple-color': yellow
        - '--mdc-ripple-press-opacity': 0.5
      icon:
        - opacity: 0.75
      name:
        - font-size: 0.5em
        - white-space: normal
      state:
        - font-size: 0.5em
      label:
        - font-size: 0.5em
  wide:
    template: standard
    styles:
      grid:
        - position: relative
        - grid-template-areas: '"i n"'
        - grid-template-columns: 1fr 1fr
        - grid-template-rows: 1fr
  container:
    color_type: label-card
    color: dimgray
    styles:
      card:
        - padding: 0
      name:
        - border-radius: 0.4em 0.4em 0 0
        - padding: 0.0em
        - width: 100%
        - font-weight: bold
        - font-size: 0.6em
      grid:
        - grid-template-areas: '"i" "n" "buttons"'
        - grid-template-rows: 1fr min-content min-content
      custom_fields:
        buttons:
          - background-color: 'rgba(0,0,0,0.3)'
          - margin: 0
          - padding: 0.15em
  standard-button:
    template: standard
    variables:
      value_on: 'on'
      value_off: 'off'
      background_color_on: gold
      background_color_off: slategrey
      text_color_on: blue
      text_color_off: white
    styles:
      label:
        - color: '[[[ return variables.text_color_off ]]]'
    state:
      - id: value_on
        value: '[[[ return variables.value_on ]]]'
        styles:
          card:
            - background-color: '[[[ return variables.background_color_on ]]]'
          name:
            - color: '[[[ return variables.text_color_on ]]]'
          icon:
            - opacity: 1
      - id: value_off
        value: '[[[ return variables.value_off ]]]'
        styles:
          card:
            - background-color: '[[[ return variables.background_color_off ]]]'
          name:
          icon:
            - opacity: 0.5
# presence-tile
  presence-tile-compact:
    color_type: card
    triggers_update: all
    aspect_ratio: 3/1.5
    tap_action:
      action: navigate
      navigation_path: /lovelace/map
    styles:
      card:
        - background-color: darkGreen
        - border-radius: 0%
        - padding: 1%
        - color: ivory
        - font-size: 11px
        - text-transform: capitalize
      grid:
        - grid-template-areas: '"n n n n n" "i i m1 m1 m1" "i i m2 m2 m2" "fam fam m3 m3 m3"'
        - grid-template-columns: 1fr 1fr 1fr 1fr 1fr
        - grid-template-rows: 1fr 1fr 1fr 1fr
      name:
        - font-weight: bold
        - font-size: 13px
        - color: white
        - align-self: middle
        - justify-self: start
        - padding-bottom: 0px
      img_cell:
        - justify-content: start
        - align-items: start
        - margin: 0%
      icon:
        - color: |
              if (entity.state == 'some home') return 'white';
              if (entity.state == 'none home') return 'lightGrey';
              else return 'yellow';
        - width: 70%
        - margin-top: 0%
      custom_fields:
        fam:
          - font-size: 10px
        m1:
        m2:
        m3:
    custom_fields:
      fam: '[[[ return `${entity.state}` ]]]'
      m1: |
          var icon = "mdi:map-marker";
          var color = "lightGrey";
          var status = states[variables.m1_entity].state;
          if (status != 'not_home') {
            icon = states['zone.'+status].attributes['icon'];
            color = "white";
          return `<span>${variables.m1_name}:</span>
          <ha-icon icon="${icon}"
          style="width: 14px; height: 14px; color: ${color};"></ha-icon>
          <span>${status}</span>`
      m2: |
          var status = states[variables.m2_entity].state;
            color = "white";
          return `<span>${variables.m2_name}:</span>
      m3: |
          var status = states[variables.m3_entity].state;
            color = "white";
          return `<span>${variables.m3_name}:</span>
This also requires the custom: button-card available through the link above and also through HACS.
It looks like this:
presence tile
For the location icons to work, you need to set up your zones with names that will “parse” properly. For example the Icc location above is based on a zone named “ICC” with an icon of “mdi:office-building”.
