I have a MySensors device. It sends battery voltage, humidity and temperature to HA. The temperature data is not changing, but the humidity and battery voltage are.
I can see the voltage data change on the device as it is sent to the MySensors Gateway. I can see the MySensors Gateway send the voltage data to the MQTT broker. I can see the voltage data on the MQTT broker. And finally, I can see the voltage data on HA using Studio Code Server.
But the voltage data does not get to the HA database config/home-assistant_v2.db and it does not appear in the card on the Dashboard and it does not appear on the device (Settings–>Devices & Services–>n_devices (mqtt MySensors)–>sensorName 130
The other data, battery voltage and humidity, do change.
Home Assistant 2023.5.2
Supervisor 2023.04.1
Operating System 10.1
Frontend 20230503.3 - latest
What’s the problem and how do I fixit?
OSD
