Sensor displaying [%key_id:state::default::off%] instead of simply "off"
Hi all, just migrated to 0.101.2. I also have a calendar (caldav) to get a specific sensor.
When I display it, it shows “[%key_id:state::default::off%]” instead of simply “off”.
This happens since 0.101.0.
Did I miss something in upgrading the configuration?
Thanks for you help.
I don’t use the caldav component. However, I use the google calendar component and my sensors are displaying correctly.
Same issue here I have binary sensor that get the state of heat water and it display [%key_id:state::default::on%]. This behavior appear from version 0.101.0.
I have the same problem for my switch. This behavior appear also since version 0.101.0.
issue opened on github :slight_smile:
Let’s see : https://github.com/home-assistant/home-assistant-polymer/issues/4181
Jenova
I confirm the issue is solved in 0.103.0
Thanks to all for your work ! HA is awesome.
