I managed to secure my HA installation with SSL. Now I’d like to add a sensor reporting the number of days until the certificate expires. I’m on TrueNAS-12.0-U2.
I managed to come up with a command which, if executed on the jail’s shell, prints the number of days:
certbot certificates 2>/dev/null | awk '/VALID:/{print $0 }' | sed 's/.*VALID: \(.*\) days.*/\1/'
I have then wrapped that command into a bash script, added permission for execution (chmod +x myscript
) and made homeassistant the owner (chown homeassistant:homeassistant myscript
). The script:
#!/usr/bin/bash
If I enter the jail’s shell and run the script, everything works as desired:
root@HomeAssistant:~ # bash /home/homeassistant/myscript
89
However, if I add an according sensor like this, the reported number is 0:
- platform: command_line
name: SSL cert expiry
unit_of_measurement: days
scan_interval: 3600
command: "bash /home/homeassistant/myscript"
What really confuses me is that if I change user on the shell, the command’s output is empty:
root@HomeAssistant:~ # su homeassistant
[homeassistant@HomeAssistant /root]$ cd
[homeassistant@HomeAssistant ~]$ bash /home/homeassistant/myscript
I’m not exactly a Linux guy, so maybe somebody can help me out here?
Thanks in advance
Christian
