Hi, what could be the problem? There should be a static line, but it keeps loading!
Should be like this:
This is the code:
entity: sensor.br_temperature
graph: line
name: Temperatuur Buienradar
type: sensor
This is the code:
graph: line
type: sensor
When you check History (sidebar), does it show the historical values of the sensors?
Hmmm, nothing there, it’s completly empty. So that might be the problem.
For me the solution was to delete the file home-assistant_v2.db located in the config of your HA folder.
Yeah, I would suggest that, sorry. Didn’t get a notification since you didn’t reply directly. But that’s what I usually do (found the solution once in another topic). Glad you could figure it out!
