Sensor Group from single MQTT with JSON
Hello all
I have a server a thome that his outputting a JSON array of temperature sensors, like this:
  "Readings": [
      "unit": "C",
      "status": "'OK'",
      "sensor_type": "Temperature",
      "temp": "27.00",
      "Type": "Temp 1",
      "ID": "14",
      "op_status": "Nominal"
      "unit": "C",
      "status": "'OK'",
      "temp": "40.00",
      "Type": "Temp 2",
      "ID": "15",
(This is just an example, there are 20+ sensors).
Using the template in Developer Options I can extract a single temperature that Iw ant but I want to be able to make a group of sensors from all of the available readings.
How can I create this in my configuration file?
Soemthig like this
- group
  temp 1:
     value_template: '[{value_json.Readings[0].temp }]'
  temp 2:
     value_template: '[{value_json.Readings[1].temp }]'
Any help in getting this done would be much appreciated
I tried to put all of my sensors into a separate servertemps.yaml
-platform: mqtt
  state_topic: 'server/temp'
  value_template: [{ value_json.Readings[0].temp }]
and this in my configuration.yaml
server_temps: !include servertemps.yaml
The problem is this works when my sensors are inn configuration.yaml but not when i include it in configuration.yaml.
I also have this in groups:
server_temps_group:
  name: Server Temperatures
  entities:
    - sensor.server_temp_0
    - sensor.serber_temp_1
But the sensors do not appear in the group
I get the following error when I reset HA
Logger: homeassistant.setup
Source: setup.py:104
Setup failed for server_temps: Integration not found.
Any thoughts please
That is not a valid include, and is not an integration either.
Create a sensor.yaml, and use
sensor: !include sensor.yaml
and put your sensor definitions in there.
So I cannot have any include name I want then? They have to be from some list?
And shouyld it be:
sensor: !include sensors.yaml
From my configuration.yaml :
python_script:
group: !include groups.yaml
script: !include scripts.yaml
binary_sensor: !include binary_sensor.yaml
switch: !include switch.yaml
light: !include light.yaml
input_boolean: !include input_boolean.yaml
timer: !include timer.yaml
scene: !include scenes.yaml
You just can’t invent topics to include, so no
and yes, if you name your sensor.yaml sensors.yaml, you just use :
Hmm
Got my server temp sensors working but I assume then that
sensors:
in configuration.yaml no longer work?
Just confirmed that myself, so is there no way to have multiple “sensors.yaml” files?
I only have like 4 sensors and the file is huge!
The final “sensor” has 30 readings from a long JSON
Since it are mqtt sensors, you can take them out of sensors.yaml and use auto-discovery messages instead. You just need to write auto-discovery messages and publish them with the retain flag set.
Another way to reduce the contents of your sensors.yaml is to use packages :
homeassistant:
  packages: !include_dir_named packages
I dont know what that means, how do I implement that?
Thanks - explains it well
