i have the following configuration for an MQTT temperature sensor:
- platform: mqtt
state_topic: "home/temperature"
it is publishing event every minute in the following json format for temp and humidity:
{“t”:“28”,“h”:“45”}
i want to display both in a graph using https://github.com/kalkih/mini-graph-card so i’m using the UI configuration:
- type: custom:mini-graph-card
name: Temperature Sensor (12H)
hours_to_show: 12
update_interval: 60
points_per_hour: 60
entities:
- sensor.temperature
The problem is that the graph expects integer values and i have them inside a json response.
What would be the proper way to set this up?
