Happy New Year everyone ![]()
A lot of work has gone into this release… you all have been asking for it so here it is. Hope you like it.
Some work is required and it is easy. If you have been using dynamic lighting, once you have updated the blueprint and would like to keep using the “Use Dynamic Lighting - Brightness” setting then select “Lux Controlled Brightness” from the dropdown menu and click save.
New Feature ![]()
Dynamic Lighting Options
- New layout to accommodate all the new options.
- Change the name of the existing dynamic selection from “Use Dynamic Lighting - Brightness” to “Lux Controlled Brightness”.
- Added “Lux Controlled Brightness - Inverted”. this work in the opposite direction to the existing Dynamic Lighting. One example on what it could be used for is your tablets on the wall controlling HA. When it is dark your tablet can be dimmed down so you don’t blind yourself. When it is bright your tablet can increase the brightness so you can see it.
- Added “Sun Elevation Lighting - Colour Temp” - This work off the suns elevation. As the sun rises you can start with a warm colour temp to then increase to a cooler colour temp. When the sun sets you can go from a cool colour temp to a warm colour temp at night.
- Added “Sun Elevation Lighting - Brightness” - This will follow the same path as the colour temp. As the sun rises you can start with a low brightness % to then increase to a higher brightness %. When the sun sets you can go from high brightness % to a lower brightness % at night.
- Added “Sun Elevation Lighting - Colour Temp + Brightness” - This uses both the colour temp and the brightness % together.
If you like this blueprint? Consider hitting the
button in the top post ![]()
If you like my blueprints, and would like to show your support or just say thank you? Click Here ![]()
Enjoy
Blacky ![]()
