๐Ÿ’ก Sensor Light - Motion Sensor - Door Sensor - Sun Elevation - LUX Value - Scenes - Time - Light Control - Device Tracker - Night Lights
New update 8.0
Your lighting experience, your way โ€“ take control and customize it to perfection! :bulb::sparkles:
:bug: Bug Fixes
Bypass - Motion trigger is off and check if any by-passes are on, fix sequence back to version 7.8
Crossing Over - When using scenes toggle helpers will change over when lights are ON.
If you like this blueprint? Consider hitting the :heart: button in the top post :+1:
If you like my blueprints, and would like to show your support or just say thank you? Click Here :smiling_face_with_three_hearts:
Enjoy
Blacky :grinning:
