Your lighting experience, your way โ take control and customize it to perfection! ![]()
Bug Fixes - Dynamic Lighting
- Toggle Helper: - Fixed various bugs in the Dynamic Lighting Toggle Helper to ensure correct toggling of the ON and OFF state.
- State Control: - Resolved issues in Dynamic Lighting state control handling.
- 0% Min Brightness Value: - Addressed bugs where setting the Dynamic Lighting min brightness value set to 0% caused the light to turn OFF, and then when transitioning to night lights, the light would remain OFF instead of transitioning properly.
- Global Conditions Triggering: - Fixed issues related to automation triggers where the light was OFF if 0% was set as a Min Brightness Value, preventing triggers from accruing properly.
Maintenance
- Updated bypass descriptions to be clearer on the function of each input based on general feedback.
- Cleaned up some code that could potentially cause an error log.
If you like this blueprint? Consider hitting the
button in the top post ![]()
If you like my blueprints, and would like to show your support or just say thank you? Click Here ![]()
Enjoy
Blacky ![]()
