Your lighting experience, your way β take control and customize it to perfection! ![]()
New Features
This has been a very popular feature request, and now itβs here! ![]()
Dim Before OFF Option
This option allows you to dim the lights as a visual warning before they turn OFF. It gives you time to trigger the motion sensor if you want the lights to stay ON.
You can find this new option in Light Control and in Night Light Control.
Ambient - Lux Time Delay
You now have an option to use a Low & High Lux Time Delay.
Low: Set how long the ambient light level must remain below the Low Lux Value before the condition is met. This helps prevent the lights from turning ON due to brief dips in lux.
High: Set how long the ambient light level must remain above the High Lux Value before the ambient condition is met. This helps prevent the lights from turning OFF due to brief spikes in lux.
Bug Fixes
- Bug in night glow when not using transition and using different lights. Light that where different would stay ON or not turn OFF.
Maintenance
- Cleaned up the bypass auto OFF conditions.
- Some descriptions update.
If you like this blueprint? Consider hitting the
button in the top post ![]()
If you like my blueprints, and would like to show your support or just say thank you? Click Here ![]()
Enjoy
Blacky ![]()
