This should not happen. I tested it here and the lights still turn ON just the one that is unavailable is not asked to do anything.
Blacky
Blacky
Hi @Blacky,
three days into the new worksweek I can say, that I donât have any issues anymore with the dynamic lights They turned on and off as expected
Thank you for your great work
I might come to you again for questions to the night lights. But before that, I will think about it a little more
kind regards
Thanks for getting back to us⌠not many people do, so itâs really nice to hear itâs now working! I ended up spending around 14 to 16 hours on it, but it was worth it. Now I can replicate this into the Smart Light blueprint.
Again thanks for letting us know
Blacky
I just wanted to let you know that Iâve developed a Holiday & Away Lighting blueprint thatâs perfect for those times when youâre heading off on vacation or even just out for the evening.
Itâs something I really recommend setting up and trying out before you actually need it. That way, you can test it, tweak it, and make sure it works exactly how you want⌠without the stress of setting it up last minute.
Itâs not just practical, itâs also a lot of fun to play around with, especially if you enjoy tinkering with your home automations like I do. You can get creative with how your lights turn ON and OFF, link different rooms together, and build something that really fits your home and your routine.
Even if youâre not going away just yet, setting it up while youâre home gives you time to fine-tune everything and make sure it works just right. So when the time comes, you can simply flip it on and head out the door⌠knowing itâs all working behind the scenes.
I hope you have fun experimenting with it! And as always, Iâd love to hear any feedback⌠whether itâs a suggestion, a bug report, or just a quick message to say itâs working well for you. Feel free to share your setups, ideas, or improvements with the community too within the actual blueprint thread, so we can all stay on topic and keep everything in one place.
Link to blueprint Holiday & Away Lighting
Enjoy
Blacky
Hi there,
i have the problem that the Ambient Control is not working for me. My intention is that the lights turn off if LUX reach 150 and turn on when LUX is 10. But nothing happens. What is my mistake?
Regards
Johannes
@Blacky I keep getting this error in. my logs
Logger: homeassistant.helpers.script
Source: helpers/script.py:697
First occurred: 25 April 2025 at 16:49:55 (2 occurrences)
Last logged: 25 April 2025 at 17:18:03
Error in 'choose[1]' evaluation: In 'or' (item 4 of 5): In 'template' condition: TypeError: unhashable type: 'list'
alias: Kitchen Motion Light
description: ""
use_blueprint:
path: Blackshome/sensor-light.yaml
input:
motion_trigger:
- binary_sensor.kitchen_motion_sensor_occupancy
include_sun: sun_disabled
time_delay: 1.5
end_scenes:
- scene.kitchen_motion_light_off
include_night_lights: night_lights_disabled
light_switch:
entity_id: scene.kitchen_motion_light_on
sun_elevation: -2
light_transition_on: 1
include_bypass:
- bypass_enabled_turn_on
motion_bypass_lights_on:
- light.kitchen_lights
ambient_light_sensor: sensor.kitchen_motion_sensor_illuminance
ambient_light_options: ambient_light_option_enabled
include_ambient: ambient_enabled
ambient_light_value: 25
ambient_light_high_value: 40
light_transition_off: 5
Everything is working here. The only thing I can think of is your using a scene or a script and you havenât enter in a toggle helper into the lights section Scenes & Scripts - Toggle Helper.
Blacky
Hi Andy,
I have tested your YAML and I can reproduce the error log but it looks like you pushed a button for the Shelly.
PS: I am on the latest version and I did change one condition for night lights. Are you on the latest version?
Blacky
I was on 8.0
must have missed the 8.1 update, Iâll test tonight see if still happens, and yes I turn off my Kitchen Lights via the wall switch, there are controlled by a shelly1.
update:
just tried the light and yes, it still happens of version 8.1
, interesting though it only happens when it use the physical switch, if I turn on/off the Kitchen Light via HA button it does not report the error.
another thing I noticed, when using the HA Button the scene Kitchen motion Light Off
actions right away when tuning off the Kitchen Light, but if I use the physical switch, it delays actioning the scene, but does action after a while.
First occurred: 14:17:05 (1 occurrences)
Last logged: 14:17:05
Using physical switch:
it looks like it actions the scene after 1.5mins (aka the timeout delay), so might be intended result.
Using HA Button:
I was looking into the logs of HA for something. And I found this very large error, which tells me, that in line 28xx something is not working, and therefore someting else is not working⌠But it does not mention if it is a spefic automation of mine, or if it is the blueprint itself. My guess is, that it is the blueprint.
Quelle: helpers/template.py:646
Erstmals aufgetreten: 14:44:37 (1 Vorkommnisse)
Zuletzt protokolliert: 14:44:37
Error doing job: Task exception was never retrieved (None)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 2385, in forgiving_float_filter
return float(value)
ValueError: could not convert string to float: 'unavailable'
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 644, in async_render
render_result = _render_with_context(self.template, compiled, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 2904, in _render_with_context
return template.render(**kwargs)
File "/usr/local/lib/python3.13/site-packages/jinja2/environment.py", line 1295, in render
self.environment.handle_exception()
File "/usr/local/lib/python3.13/site-packages/jinja2/environment.py", line 942, in handle_exception
raise rewrite_traceback_stack(source=source)
File "<template>", line 1, in top-level template code
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 2388, in forgiving_float_filter
raise_no_default("float", value)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 1942, in raise_no_default
raise ValueError(
...<2 lines>...
ValueError: Template error: float got invalid input 'unavailable' when rendering template '{% set lux = states(dynamic_lighting_lux_sensor) | float %} {% set slope = (dynamic_lighting_min_brightness - dynamic_lighting_max_brightness) / (dynamic_lighting_max_lux - dynamic_lighting_min_lux) %} {% set ak = (( slope * dynamic_lighting_min_lux) * -1) + dynamic_lighting_max_brightness %} {% set le = light_entities %} {% set lec = expand(le) | map(attribute='entity_id') | list | length %} {% set lp = (expand(le) | map(attribute='attributes.brightness') | reject('equalto', None) | sum | float(default=255) / 255 * 100 / lec) | round(0) %} {% if lux <= dynamic_lighting_min_lux %}
{% set bv = dynamic_lighting_max_brightness %}
{% elif lux >= dynamic_lighting_max_lux %}
{% set bv = dynamic_lighting_min_brightness %}
{% else %}
{% set bv = ((slope * lux) + ak) | round(1) %}
{% endif %} {% if lp <= 0 %}
{% set bv = bv %}
{% elif (bv > lp) and (dynamic_lighting_max_brightness - lp) <= dynamic_lighting_dead_zone %}
{% elif (lp > bv) and (lp - dynamic_lighting_min_brightness) <= dynamic_lighting_dead_zone %}
{% elif (bv > lp) and (bv - lp) <= dynamic_lighting_dead_zone %}
{% set bv = lp %}
{% elif (lp > bv) and (lp - bv) <= dynamic_lighting_dead_zone %}
{% set bv = lp %}
{% elif bv > (lp + dynamic_lighting_step_value) %}
{% set bv = lp + dynamic_lighting_step_value %}
{% elif bv < (lp - dynamic_lighting_step_value) %}
{% set bv = lp - dynamic_lighting_step_value %}
{% endif %} {{ bv | round(0) }}' but no default was specified
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 460, in async_run
await self._async_step(log_exceptions=False)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 526, in _async_step
self._handle_exception(
ex, continue_on_error, self._log_exceptions or log_exceptions
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 556, in _handle_exception
raise exception
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 524, in _async_step
await getattr(self, handler)()
File "/usr/src/homeassistant/homeassistant/helpers/trace.py", line 283, in async_wrapper
await func(*args)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 664, in _async_step_parallel
raise result
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 656, in async_run_with_trace
await self._async_run_script(script, parallel=True)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 632, in _async_run_script
result = await self._async_run_long_action(
...<6 lines>...
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 624, in _async_run_long_action
return await long_task
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1827, in async_run
return await asyncio.shield(create_eager_task(run.async_run()))
raise exception
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 715, in _async_step_choose
await self._async_run_script(script)
...<6 lines>...
raise exception
await func(*args)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 938, in _async_step_repeat
await self._async_do_step_repeat()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 894, in _async_do_step_repeat
await async_run_sequence(iteration)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 790, in async_run_sequence
...<6 lines>...
raise exception
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 972, in _async_step_variables
self._action[CONF_VARIABLES].async_simple_render(self._variables)
File "/usr/src/homeassistant/homeassistant/helpers/script_variables.py", line 81, in async_simple_render
rendered_variable = template.render_complex(value, run_variables)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 267, in render_complex
return value.async_render(variables, limited=limited, parse_result=parse_result)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 646, in async_render
raise TemplateError(err) from err
homeassistant.exceptions.TemplateError: ValueError: Template error: float got invalid input 'unavailable' when rendering template '{% set lux = states(dynamic_lighting_lux_sensor) | float %} {% set slope = (dynamic_lighting_min_brightness - dynamic_lighting_max_brightness) / (dynamic_lighting_max_lux - dynamic_lighting_min_lux) %} {% set ak = (( slope * dynamic_lighting_min_lux) * -1) + dynamic_lighting_max_brightness %} {% set le = light_entities %} {% set lec = expand(le) | map(attribute='entity_id') | list | length %} {% set lp = (expand(le) | map(attribute='attributes.brightness') | reject('equalto', None) | sum | float(default=255) / 255 * 100 / lec) | round(0) %} {% if lux <= dynamic_lighting_min_lux %}
{% else %}
{% set bv = bv %}
{% set bv = lp %}
{% set bv = lp %}
OK, it might be the lux controlled âArbeitslichtâ. But right now, it is working. The light turn on and off and gets lighter or darker. So for me it is ok, but maybe not for the engineer behind it
Logger: homeassistant.components.automation.arbeitslicht
Quelle: helpers/script.py:2057
Integration: Automation (Dokumentation, Probleme)
Erstmals aufgetreten: 14:42:30 (4 Vorkommnisse)
Arbeitslicht: Choose at step 1: default: Parallel actions for dynamic lighting and normal lights: parallel 1: Choose at step 3: 1 - Dynamic Lighting - Lux Controlled Brightness: Dynamic Lighting Control: Error executing script. Error rendering template for variables at pos 1: ValueError: Template error: float got invalid input 'unavailable' when rendering template '{% set lux = states(dynamic_lighting_lux_sensor) | float %} {% set slope = (dynamic_lighting_min_brightness - dynamic_lighting_max_brightness) / (dynamic_lighting_max_lux - dynamic_lighting_min_lux) %} {% set ak = (( slope * dynamic_lighting_min_lux) * -1) + dynamic_lighting_max_brightness %} {% set le = light_entities %} {% set lec = expand(le) | map(attribute='entity_id') | list | length %} {% set lp = (expand(le) | map(attribute='attributes.brightness') | reject('equalto', None) | sum | float(default=255) / 255 * 100 / lec) | round(0) %} {% if lux <= dynamic_lighting_min_lux %} {% set bv = dynamic_lighting_max_brightness %} {% elif lux >= dynamic_lighting_max_lux %} {% set bv = dynamic_lighting_min_brightness %} {% else %} {% set bv = ((slope * lux) + ak) | round(1) %} {% endif %} {% if lp <= 0 %} {% set bv = bv %} {% elif (bv > lp) and (dynamic_lighting_max_brightness - lp) <= dynamic_lighting_dead_zone %} {% set bv = dynamic_lighting_max_brightness %} {% elif (lp > bv) and (lp - dynamic_lighting_min_brightness) <= dynamic_lighting_dead_zone %} {% set bv = dynamic_lighting_min_brightness %} {% elif (bv > lp) and (bv - lp) <= dynamic_lighting_dead_zone %} {% set bv = lp %} {% elif (lp > bv) and (lp - bv) <= dynamic_lighting_dead_zone %} {% set bv = lp %} {% elif bv > (lp + dynamic_lighting_step_value) %} {% set bv = lp + dynamic_lighting_step_value %} {% elif bv < (lp - dynamic_lighting_step_value) %} {% set bv = lp - dynamic_lighting_step_value %} {% endif %} {{ bv | round(0) }}' but no default was specified
Arbeitslicht: Choose at step 1: default: Parallel actions for dynamic lighting and normal lights: parallel 1: Choose at step 3: 1 - Dynamic Lighting - Lux Controlled Brightness: Error executing script. Error rendering template for repeat at pos 1: ValueError: Template error: float got invalid input 'unavailable' when rendering template '{% set lux = states(dynamic_lighting_lux_sensor) | float %} {% set slope = (dynamic_lighting_min_brightness - dynamic_lighting_max_brightness) / (dynamic_lighting_max_lux - dynamic_lighting_min_lux) %} {% set ak = (( slope * dynamic_lighting_min_lux) * -1) + dynamic_lighting_max_brightness %} {% set le = light_entities %} {% set lec = expand(le) | map(attribute='entity_id') | list | length %} {% set lp = (expand(le) | map(attribute='attributes.brightness') | reject('equalto', None) | sum | float(default=255) / 255 * 100 / lec) | round(0) %} {% if lux <= dynamic_lighting_min_lux %} {% set bv = dynamic_lighting_max_brightness %} {% elif lux >= dynamic_lighting_max_lux %} {% set bv = dynamic_lighting_min_brightness %} {% else %} {% set bv = ((slope * lux) + ak) | round(1) %} {% endif %} {% if lp <= 0 %} {% set bv = bv %} {% elif (bv > lp) and (dynamic_lighting_max_brightness - lp) <= dynamic_lighting_dead_zone %} {% set bv = dynamic_lighting_max_brightness %} {% elif (lp > bv) and (lp - dynamic_lighting_min_brightness) <= dynamic_lighting_dead_zone %} {% set bv = dynamic_lighting_min_brightness %} {% elif (bv > lp) and (bv - lp) <= dynamic_lighting_dead_zone %} {% set bv = lp %} {% elif (lp > bv) and (lp - bv) <= dynamic_lighting_dead_zone %} {% set bv = lp %} {% elif bv > (lp + dynamic_lighting_step_value) %} {% set bv = lp + dynamic_lighting_step_value %} {% elif bv < (lp - dynamic_lighting_step_value) %} {% set bv = lp - dynamic_lighting_step_value %} {% endif %} {{ bv | round(0) }}' but no default was specified
Arbeitslicht: Choose at step 1: default: Parallel actions for dynamic lighting and normal lights: parallel 1: Error executing script. Error rendering template for choose at pos 3: ValueError: Template error: float got invalid input 'unavailable' when rendering template '{% set lux = states(dynamic_lighting_lux_sensor) | float %} {% set slope = (dynamic_lighting_min_brightness - dynamic_lighting_max_brightness) / (dynamic_lighting_max_lux - dynamic_lighting_min_lux) %} {% set ak = (( slope * dynamic_lighting_min_lux) * -1) + dynamic_lighting_max_brightness %} {% set le = light_entities %} {% set lec = expand(le) | map(attribute='entity_id') | list | length %} {% set lp = (expand(le) | map(attribute='attributes.brightness') | reject('equalto', None) | sum | float(default=255) / 255 * 100 / lec) | round(0) %} {% if lux <= dynamic_lighting_min_lux %} {% set bv = dynamic_lighting_max_brightness %} {% elif lux >= dynamic_lighting_max_lux %} {% set bv = dynamic_lighting_min_brightness %} {% else %} {% set bv = ((slope * lux) + ak) | round(1) %} {% endif %} {% if lp <= 0 %} {% set bv = bv %} {% elif (bv > lp) and (dynamic_lighting_max_brightness - lp) <= dynamic_lighting_dead_zone %} {% set bv = dynamic_lighting_max_brightness %} {% elif (lp > bv) and (lp - dynamic_lighting_min_brightness) <= dynamic_lighting_dead_zone %} {% set bv = dynamic_lighting_min_brightness %} {% elif (bv > lp) and (bv - lp) <= dynamic_lighting_dead_zone %} {% set bv = lp %} {% elif (lp > bv) and (lp - bv) <= dynamic_lighting_dead_zone %} {% set bv = lp %} {% elif bv > (lp + dynamic_lighting_step_value) %} {% set bv = lp + dynamic_lighting_step_value %} {% elif bv < (lp - dynamic_lighting_step_value) %} {% set bv = lp - dynamic_lighting_step_value %} {% endif %} {{ bv | round(0) }}' but no default was specified
Arbeitslicht: Choose at step 1: default: Error executing script. Error rendering template for parallel at pos 4: ValueError: Template error: float got invalid input 'unavailable' when rendering template '{% set lux = states(dynamic_lighting_lux_sensor) | float %} {% set slope = (dynamic_lighting_min_brightness - dynamic_lighting_max_brightness) / (dynamic_lighting_max_lux - dynamic_lighting_min_lux) %} {% set ak = (( slope * dynamic_lighting_min_lux) * -1) + dynamic_lighting_max_brightness %} {% set le = light_entities %} {% set lec = expand(le) | map(attribute='entity_id') | list | length %} {% set lp = (expand(le) | map(attribute='attributes.brightness') | reject('equalto', None) | sum | float(default=255) / 255 * 100 / lec) | round(0) %} {% if lux <= dynamic_lighting_min_lux %} {% set bv = dynamic_lighting_max_brightness %} {% elif lux >= dynamic_lighting_max_lux %} {% set bv = dynamic_lighting_min_brightness %} {% else %} {% set bv = ((slope * lux) + ak) | round(1) %} {% endif %} {% if lp <= 0 %} {% set bv = bv %} {% elif (bv > lp) and (dynamic_lighting_max_brightness - lp) <= dynamic_lighting_dead_zone %} {% set bv = dynamic_lighting_max_brightness %} {% elif (lp > bv) and (lp - dynamic_lighting_min_brightness) <= dynamic_lighting_dead_zone %} {% set bv = dynamic_lighting_min_brightness %} {% elif (bv > lp) and (bv - lp) <= dynamic_lighting_dead_zone %} {% set bv = lp %} {% elif (lp > bv) and (lp - bv) <= dynamic_lighting_dead_zone %} {% set bv = lp %} {% elif bv > (lp + dynamic_lighting_step_value) %} {% set bv = lp + dynamic_lighting_step_value %} {% elif bv < (lp - dynamic_lighting_step_value) %} {% set bv = lp - dynamic_lighting_step_value %} {% endif %} {{ bv | round(0) }}' but no default was specified
Looks like when your using dynamic lighting your lux sensor is unavailable. I contemplated if I should put a default value in but then it may not be the correct value and adjust the lights
Blacky
moving to the right thread, sorry about that
OK, thank you. What is funny, that it the automation is working as it should.
first of all, its the best blueprint in the web - great work!
second:
I face a odd issue that my âbypass helperâ is not turned off after the selected
âBypass Auto OFF Optionâ
the âKĂźche Blocker Helperâ turns the lights on, but they stay âonâ forever, same as the helper does. If i manually turn the helper off, the light goes off like it should.
I use the blueprint in a similar fashion with an option 2 blocker, so force light off - and this seem to work fine.
Blacky,
I notice the Bypass turn ON lights doesnt work with Night Lights. It seems to leave the lights at the night lights brightness. This doesnt seem to be expected behaviour, since the Bypass documentation above indicates it should work in any circumstance. Love your work.
alias: Ensuite Lights
description: ""
use_blueprint:
input:
motion_trigger:
- binary_sensor.md_master_bed_group
light_switch:
entity_id:
- light.hue_ensuite_downlight_color
- light.hue_color_lamp_1
- light.hue_white_lamp_1
include_bypass:
motion_bypass_lights_off: []
ambient_light_sensor: sensor.hue_motion_sensor_1_illuminance
include_night_lights: night_lights_enabled
night_lights_entity_state:
- input_boolean.meinbed
- input_boolean.wifeinbed
night_lights_conditions:
- entity_state_enabled
night_lights:
entity_id:
night_time_delay: 2
include_night_light_control:
- use_brightness
- use_transition
- if_lights_are_on_adjust_when_crossing_over
night_light_brightness: 10
night_light_transition_on: 0.5
include_night_light_colour_control: disable_colour_control
include_light_control:
- use_brightness
- input_boolean.ensuite_lights_bypass
include_bypass_auto_off: []
bypass_auto_off_delay: 10
Welcome to the community!
Thanks for your kind words.
Thanks for the screen shot that helps me. You have chosen bypass Option 1 so the auto OFF is Option A. You have selected auto OFF Option B. Please select Option A and you be good to go. See below.
Blacky
When the bypass is turned ON using option 1, the automation will turn ON the normal or night lights, depending on which is active at the time.
I have tested it here again and is working.
Blacky
Is my yaml correct? itâs not working
description: ""
use_blueprint:
input:
motion_trigger:
light_switch:
entity_id:
include_bypass:
night_lights:
entity_id:
