Hello Every One, il have a solar energy meter (MK10) use for calculating my production of energy. It was until now sealed for the purposes of verifying green certificates in Belgium but my 10 year period has just ended so I can have access to the mk10, I wanted to know if anyone had already managed to recover the data directly from the MK10? THANKS
Here some information about MK10
I am allso intrested…
Communications ports:
• Up to 3 independently working
communication ports:
- Optical port: FLAG (IEC 62056-21) or
ANSI type 2 (ANSI C12.18) - RS-232 with modem power supply
(It supports most modems in the
market) - RS-485 multi-drop (2 or 4-wire RJ45
or 2-wire screw terminal)
• Option for passive RS-232 or second
RS-232 port
• UDP/IP/PPP/GPRS capable
• MV-90™ compatible
Protocol
• EDMI command line
• MODBUS
MK10 manual
HI Thomas.dmm. Were you able to find something ? I also would like to connecte my MK10a (mine is “a”) but I do not find a lot of solution on the web (except generic solutions like using clamps or counting the led flash). Thanks
Hello no i don’t find anything
