That the Template Sensor’s template. I need to see the Template Sensor’s configuration.
If you created the Template Sensor via YAML, post its YAML.
If you created the Template Sensor as a helper via the UI, post a screenshot. (I believe that’s how you created it because you have shown a screenshot of its “Preview”)
Also, which one of those 9 add-ons has an available update?
