Sensor shows completly wrong value
Hello together,
Yesterday, I experienced a weird behavior in HA. We have two Fronius Wattpilot chargers at home. One is always on and the second one was off till yesterday, because we didn’t need it.
Both were already set up in HA and integrated into the energy dashboard. The community add on provides all kinds of information and functionalities, including the totally charged value, which I use for the dashboard.
Now the problem, the sensor has the correct value and is set up correctly, but in the dashboard it shows a completely different value.
I checked the configuration of the dashboard several times, removed and added the sensor, restarted HA, but nothing helped. Only thing I did not was to remove and add the device from HA, but how can this happen, when the sensor is correct but displays a wrong value?
