Hi all,
i have a Daikin AC installed by its integration.
Integration has internal sensor for ‘internal_temperature’, the sensor is on AC case but in my case is useless.
I’d like to use another temperature sensor in this integration, because i need a real temperature for target temperature.
I tried to overwrite “internal_temperature” with a template but i think it’s not possible.
How can i do? i need to modify .py files?
I have the same problem, this integration is perfect and the air conditioner is recognized immediately.
But using the internal sensors (temp, humidity) doesn’t make sense, the temperature is distorted and you need to be able to use external sensors as you do with IR integration…
I find it hard to understand that this is not foreseen but after spending hours searching I have found nothing…
