pitp2
May 26, 2019, 7:07pm
1
I created a sensor to catch a temperature.
I have two questions :
Is it possible to use the template directly in the scrape ?
If it’s not possilbe, how can I update the entity when the value change ?
- platform: scrape
resource: http://192.168.0.3/details.xml
select: "PrimaryValue"
sensors:
temp_piscine:
entity_id: sensor.temppiscine
friendly_name: Température piscine
value_template: "{{ states('sensor.temp_piscine_scrape').split(' ')[0] |round(2) }}"
device_class: temperature
unit_of_measurement: "°C"
I hope you can help me :=)
The docs show no ‘value_template’ in the configuration variables, but the examples do.
I think it should work with one sensor, just give it a try.
pitp2
June 1, 2019, 12:31pm
3
I tried to use a value_template in a scrape platefomr but this don’t work
123
(Taras)
June 1, 2019, 12:53pm
4
I examined the scrape sensor’s source-code and value_template
is supported.
pitp2
June 1, 2019, 1:16pm
5
It’s strange because I tried this and I have no value …
platform: scrape
select: “PrimaryValue”
unit_of_measurement: “°C”
value_template: “{{ states(‘sensor.temp_piscine_pac_scrape’).split(’ ')[0] |round(2) }}”
123
(Taras)
June 1, 2019, 2:02pm
6
pitp2:
It’s strange
Not really. Think about what this template is trying to do:
value_template: "{{ states('sensor.temp_piscine_pac_scrape').split(' ')[0] |round(2) }}"
Its purpose is to set the state of of sensor.temp_piscine_pac_scrape
. It attempts to do that by getting its own state which it will split … oh wait … how is it going to get its own state if it has never set it yet ?
Try this:
value_template: "{{ value.split(' ')[0] | round(2) }}"
In the future, please format your code. YAML indenting and quotation characters are critical for proper operation and they’re all lost if you don’t format your code.
pitp2
June 2, 2019, 9:34am
7
Sorry for stupid questions
It’s ok now with your code …
Thank you for your help
Now I wolud like to parse the xml file above. The porblem is that I would like to catch those values “PrimaryValue”
I can catch the first one but I don’t know how to catch the second one …
Do you know how to do this ?
<Devices-Detail-Response xmlns="http://www.embeddeddatasystems.com/schema/owserver" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<PollCount>15035426</PollCount>
<DevicesConnected>2</DevicesConnected>
<LoopTime>0.066</LoopTime>
<DevicesConnectedChannel1>0</DevicesConnectedChannel1>
<DevicesConnectedChannel2>0</DevicesConnectedChannel2>
<DevicesConnectedChannel3>2</DevicesConnectedChannel3>
<DataErrorsChannel1>92</DataErrorsChannel1>
<DataErrorsChannel2>0</DataErrorsChannel2>
<DataErrorsChannel3>5510547</DataErrorsChannel3>
<VoltageChannel1>4.27</VoltageChannel1>
<VoltageChannel2>4.41</VoltageChannel2>
<VoltageChannel3>4.16</VoltageChannel3>
<VoltagePower>4.63</VoltagePower>
<DeviceName>OWServer_v2-Enet</DeviceName>
<HostName>EDSOWSERVER2</HostName>
<MACAddress>00:04:A3:59:29:05</MACAddress>
<owd_DS18B20 Description="Programmable resolution thermometer">
<Name>DS18B20</Name>
<Family>28</Family>
<ROMId>D30000027B792928</ROMId>
<Health>1</Health>
<Channel>3</Channel>
<RawData>
DA014B465FFF06104100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
</RawData>
<PrimaryValue>29.6250 Deg C</PrimaryValue>
<Temperature Units="Centigrade">29.6250</Temperature>
<UserByte1 Writable="True">75</UserByte1>
<UserByte2 Writable="True">70</UserByte2>
<Resolution>11</Resolution>
<PowerSource>0</PowerSource>
</owd_DS18B20>
<Family>28</Family>
<ROMId>140000038B657B28</ROMId>
<Health>1</Health>
<RawData>
E2014B467FFF0E109100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
</RawData>
<PrimaryValue>30.1250 Deg C</PrimaryValue>
<Temperature Units="Centigrade">30.1250</Temperature>
<Resolution>12</Resolution>
</owd_DS18B20>
</Devices-Detail-Response>
pitp2
June 2, 2019, 10:48am
8
I found :=)
I used this code to navigate in the xml file
select: 'PrimaryValue'
index: 2
