Sensors do not update without the Companion App (Iphone) open
For a few days now I have been experiencing a phenomenon with the Companion App (2025.7.1 (2025.1342)) on my iPhone.
If it is not open in the foreground, no sensors such as the charging status of the iPhone are updated. So far, this has always worked great and reliably, but apparently there was a July update of the app (see version number), which now seems to be causing the problem.
I have already deleted the iPhone from the Mobile App Integration and added it again, and I have also deleted and reinstalled the Companion App. All without success, unfortunately. As far as I know, a downgrade is not possible on the iPhone.
I granted the app all the permissions that it requested.
The charging entity in particular is important for various automations and I would be very sorry if this no longer works in the future.
Do you know the problem and do you have a solution?
Greetings
sven
I’m having the exact same problem. Sometime within the last couple of weeks, automations that triggered when I took my phone off of the charger now don’t trigger until I reopen the app.
+1 same problem
+1 Another one with this same issue. I normally have quite a few automations driven off my phone going on or off charge at certain times in the day. Doesnt look like the log within Home Assistant is even picking up these changes anymore, even with the app open an in the foreground
adding my +1
I use my ipad as a wall dashboard, I use a kiosk app so that I have a nice clock screensaver vs the screen being 100% all the time. used to be fine having the HA app closed with sensors in the background but last week woke up to a dead battery because the automation never triggered to charge. Anyone find a solution?
:white_check_mark: FIX: Take a look in the Home Assistant companion app on your mobile device. Go to Settings > Companion App > Sensors. Check ā€˜Enable all sensors’. Just found this (apparently new) setting on my iPhone.
I have also problems with sensor not updating too. My Auto Unlock automations won’t work because what I think has to do with the sensor updates not working properly. My ssid and connection type won’t update with the app in the background at least when I change manually from wifi to cellular for testing. :frowning:
I’ve noticed the same thing. ā€œEnable all sensorsā€ is already set in my companion app, but oddly I can’t turn it off (I thought turning it off and back on again might fix something).
I’ve got all permissions open and ā€œPeriodic Updatedā€ set to 1 minute.
This seems like a recent change: my iPhone sensors used to update very frequently. Now hardly at all (only when I open the app).
I have the same problem, I have some automations that, inside my home wifi, use the sensor ā€œactivityā€ when move to ā€œautomotiveā€ as trigger, when I jump in the car. I have the iphone banner that confirm the sensors have been updated, but I have to open the companion app to run the automation. All sensors enabled in the settings.
Thank you for the tip, this was driving me crazy today.
Same problem, same fix, thanks man!
Is not working on my side. I have an iPad and Home Assistant app is running in the background. Enable all sensors ist enabled but it is only sending the data when the app is in foreground :frowning:
What I’m trying is to get my battery level into home assistant. My plan is so send a notification if the batery level is getting below 20%
Hope they will fix that but don’t looks like that :frowning:
I’m experiencing the same issue and trying to achieve the exact same thing as you. But no matter what i do, the sensors will only update when the app is opened up in the forground :frowning:
I found a workaround solution here
It’s basically a scheduled automation that perdioically sends the companion app a request for it to update it’s location and it pulls all the other sensor data through with it. Seems to have done the trick for me. Hope it works for your scenario too
Oh sounds good, I will give it a try! Thank you so much!
It didn’t work for me :frowning: I noticed the sensors update right away when I plug/unplug the charger. But that is not the solution that I want :smiley:
this worked for me!!
