I have 3 Blink cams installed. They were working well with 3 sensors each viz. battery, wireless, temperature. Out of the blue, no changes to the setup hassio produces the error message “entity not available: sensor_xxxx_temperature”. Other sensors still there but the Blink items are gone.
Any help on how to even troubleshoot this issue will be much appreciated.
Blink changed the API endpoint (again). A fix has been developed:
Ah, so just wait for the next release then?
I believe so. I haven’t found a way to manually update just the Blink component (although I am sure that this is possible).
Thanks, saved me hours of trying to find out what went wrong. I had not made any config changes which is where I’d usually start. Much appreciated.
Not fixed in 0.89
That’s a pity. Fairly new to HA - will there be another release in the near future that may have the fix?
Not really sure how quickly fixes get rolled out…?
Yeah i don’t know why it wasn’t added to 0.89 but it’s marked to be added to 0.89.1
Fixed! Woohoo, thanks a lot.
