Sensors - how to change number display style/precision "on the fly"?
in case of my topic wasn’t too clear, here’s the explaination of my question:
I’ve got a sensor that reads from the water meter. let’s call it sensor.water_read. it is numeric and looks like this: 123456, with the liter as display unit.
when the invoice guy comes to ask for readouts, he needs cubic meters, so in case of sensor.water_read it’s just 123.
I want to display the sensor.water_read in a nice form, but also keep the original numbers for other calculations [like daily/monthly stats, sprinkler useage etc.]. so until now I used sensor.water_read for calculations and I had an additional template sensor, let’s call it sensor.water_display, with below config - just for making it nice in lovelace.
    sensors:
      water_display:
        value_template: "{{ '{0:,}'.format(states('sensor.water_read')|int/1000)|replace(',',' ')|replace('.',',') }}"
        unit: "m³"
and it gave me a nice 123,456 m3 as output in the dashboard.
but that solution isn’t perfect - because it duplicates the sensor just for sake of displaying it another way - so I wonder, if there’s a way to set some options to display the sensor in way I want [with comma and different unit etc.] but within the very same entity? without duplicating it with template sensor? like reformatting it on-the-fly?
You could use custom button card, with that as the entity, but use a label_template, and pretty much paste that jiggery you have in there.
thanks!
I was thinking about “a native” solution [meaning: with stock featuers] and forgot about custom button card, that can be used just for a display [this “button” part of the name is always confusing me ;)]. playing with it now. looks like the best/easiest solution.
