Sent commands wont work
Hello guys, I’m trying a ZS06 with ZHA integration and needed quirk. On one AC (LG) the code readed is ok, and works when sent. But those codes readed from a Electrolux AC wont work. I’ve already tried changing places but no luck. Codes changes every time i read then, but don’t think this is the problem, since in other topic I saw that’s a common thing for IR.
Any ideas?
It probably is. I think most IR blasters are designed for relatively simple applications where there is a one-to-one relationship between button and command - a TV for example.
