I tried many things, researched the forum, but i just could not find the right configuration, but i feel like its right under my nose.
I have a serial LORA gateway that return ASCII strings.
Exampleo of strings coming into the serial port of HASSIO: (checked with putty on pc)
GW_ID:2818050,TYPE:CO2,ID:1200001041,STAT:00000011,CO2:888PPM,T:28.2▒▒,H:32.0%,ST:5M,V:3.38v,SN:6,RSSI:-40dBm,S:22.5769,E:113.9712,Time:2020-4-24 0:39:4,T_RSSI:-40dBm
How can i get the values: C02, Temp, Humidity out of this string?
Thank u!
Regards,
JJA Vogels
