Serial ports?
HA OS on a Rpi4:
Is there a limit for the NUMBER of serial ports that will initialize at startup?
I get an effect indicating that only TWO USB-serial ports will startup at any reboot.
I have TWO GPS:es that show up as /dev/ttyUSB0 and /dev/ttyUSB1
if I unplug one of them I get my ConBee (ZHA) as /dev/ttyACM0
Have you checked the output of dmesg when all are plugged in, or when unplugging and plugging the missing device? I don’t think there is a limit to the number of USB or serial ports you can have. You should also use the by-id device string as the tty devices can change positions after a reboot.
