Serial Sensor get only read once at boot
I am new to Home Assistant and I build a serial sensor, to get data from my Victron SolarCharger by ve.direct usb cable.
My problem is, that I only get one reading at boot. For one time, I got new readings every second, but after a reboot, that stops.
I use Home Assistant OS as a proxmox ve VM.
Can someone give me a tip, what is wrong?
In my sensor.yaml I add this.
  - platform: serial
    serial_port: /dev/serial/by-id/usb-VictronEnergy_BV_VE_Direct_cable_VE735TSL-if00-port0
    baudrate: 19200
    value_template: "{{ value }}"
I think, I have solved it.
I only did a reboot of Home Assistant over the WebGUI and reboot the hole system over proxmox, but after I rebooted the hole system over the WebGUI, I got all the readings.
So my question, is there a difference, when I reboot the VM over proxmox or over the HA WebGUI?
OK, it is not solved, after one minute I get no new readings.
