Serial sensor integration
Maybe some of you have had a similar problem with the serial port…
  • HA (2025.10) as a VM in Proxmox;
  • Prolific pl2303 converter connected to the USB port;
  • USB passthrough as device ID;
  • recognized in HA
# dmesg -T |grep tty
[Wed Oct  8 23:00:19 2025] usb 2-1: pl2303 converter now attached to ttyUSB0
Cable/converter for 100% works fine - when I do
# cat /dev/ttyUSB0
I see the correct messages on the terminal/console send by RS232 device
Configured serial in HA as:
  - platform: serial
    baudrate: 2400
    serial_port: /dev/ttyUSB0
BUT the entity sensor.serial_sensor itself has state: unknown…
This configuration worked for more then years - what has changed:
  • about month ago I had to replace RS232 end device but new one has the same RS232 parameters, configurations etc
  • updated HA from 2025.09.xx
Any idea?
Also interested…
