Hello.
I know it is a little off topic, but I have seen, that several people want to control a simple unit ( Heater, Solar Charger, … ) that has a serial port.
I think, the best solution is, that one could use ESPhome with a simple serial2mqtt interface. That way, you can easily integrate the hardware into almost everything and still use the ESPhome goodness for other stuff.
Since I am stuck with that UART interface in ESPhome, I have created a ticket for a solution. Perhaps you guys can take a look at it an help. This would open up a whole lot of new sensors for Home Assistant!
Thank you guys for the fast reply.
I will change the ticket to features …
Yes, it should be really easy. I mean, basically, you need to pipe the mqtt topic on the serial port (should work in the code I put in the ticket) AND pipe the serial output to the mqtt topic. Since there is no on_receive or similar, that is not possible just using yaml.
Yes. Somehow with a custom component it should work, but since there is now howto or sample code, it will scare a lot of people away ( like me )
Well this should do what you want according to the link Nick posted above.:
Save this config:
#include "esphome.h"
class UartReadLineSensor : public Component, public UARTDevice, public TextSensor {
public:
UartReadLineSensor(UARTComponent *parent) : UARTDevice(parent) {}
void setup() override {
// nothing to do here
int readline(int readch, char *buffer, int len)
static int pos = 0;
int rpos;
if (readch > 0) {
switch (readch) {
case '\n': // Ignore new-lines
break;
case '\r': // Return on CR
rpos = pos;
pos = 0; // Reset position index ready for next time
return rpos;
default:
if (pos < len-1) {
buffer[pos++] = readch;
buffer[pos] = 0;
// No end of line has been found, so return -1.
return -1;
void loop() override {
const int max_line_length = 80;
static char buffer[max_line_length];
if (available() && readline(read(), buffer, max_line_length) > 0) {
publish_state(buffer);
As a file called uart_read_line_sensor.h in your configuration directory.
In addition to your wifi, mqtt/api, etc… setup, include this in your esphome device config:
