I am trying to add a service-button in lovelace, but when i press it in the front end, instead of toggling the single automation, it toggles all automations.
Is my code correct or is this a bug? I’m on Hassio vsn 83.3
That should work. Have you tried the service inside HA instead of lovelace? If it’s a lovelace issue, you could make a template switch that turns on and off the automation.
I can use the dev-service page to test toggle the automation without problem, and I have a this code below where the ‘type: image’ just above toggles the exact same thing - again without problem.
Do you think this may be a bug within lovelace then?
