Service Calls in automation help
I already managed to create some automations, but I´m stuck on this one when doing the config check.
The goal is to turn off 2 power sockets when my daughter is leaving, as she only visits me every 2 weeks. But before turning of the sockets, her raspberry and surface tablet shall shutdown gracefully.
this is the code and I don´t get what´s wrong, as it shows me an “Error loading /config/configuration.yaml: mapping values are not allowed here”
Any suggestions?
- id: '0031'
  hide_entity: false
  alias: amy-steckdosen-aus-wenn-weg
  - entity_id: device_tracker.google_maps_100570646164841679632
    event: leave
    platform: zone
    zone: zone.home
  condition:
  - entity_id: device_tracker.androidnokia
    platform: state
    to: away
  - service: media_player.kodi_call_method
        entity_id: media_player.kodi_surface
        method: System.Shutdown
        entity_id: media_player.kodi_amy
  - delay: 00:00:30
  - service: switch.turn_off
    entity_id: switch.socket02
    entity_id: switch.socket03
Thanks,
Philipp
You should also be given a line number in the error message.
you have too many indentations in the service calls at the “data” lines.
move everything in those lines back two spaces.
