Guys my HA won’t now pull a camera.snapshot from any of my three IP cameras. Two are using the generic platform and one the Amrcest platform. All worked fine on HA 0.114.
Tried using the developer tools to hand launch a snapshot but it ‘fails to call service’ with ‘camera undefined’ as the error type.
My cameras still have the same names as they did before and I can view their picture cards as normal.
Any clues ? Did service call syntax get changed in 0.115 ?
LOG
Logger: homeassistant.components.websocket_api.http.connection.1777376128
Source: helpers/template.py:287
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 9:54:48 PM (10 occurrences)
Last logged: 10:09:05 PM
UndefinedError: 'camera' is undefined
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 285, in async_render
return compiled.render(kwargs).strip()
File "/usr/local/lib/python3.8/site-packages/jinja2/environment.py", line 1090, in render
self.environment.handle_exception()
File "/usr/local/lib/python3.8/site-packages/jinja2/environment.py", line 832, in handle_exception
reraise(*rewrite_traceback_stack(source=source))
File "/usr/local/lib/python3.8/site-packages/jinja2/_compat.py", line 28, in reraise
raise value.with_traceback(tb)
File "<template>", line 1, in top-level template code
File "/usr/local/lib/python3.8/site-packages/jinja2/sandbox.py", line 407, in getattr
value = getattr(obj, attribute)
jinja2.exceptions.UndefinedError: 'camera' is undefined
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 137, in handle_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 1315, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1350, in _execute_service
await handler.func(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 204, in handle_service
await self.hass.helpers.service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 459, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 655, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 490, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/camera/__init__.py", line 653, in async_handle_snapshot_service
snapshot_file = filename.async_render(variables={ATTR_ENTITY_ID: camera})
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 287, in async_render
raise TemplateError(err) from err
homeassistant.exceptions.TemplateError: UndefinedError: 'camera' is undefined
