Service_template error: Invalid config for [automation]: expected dictionary @ data['action'][0]. Got None
I’m struggling with the following automation code:
- id: Set_opritcamera_mode
  alias: "Set Opritcamera Mode"
    - platform: state
      entity_id: input_select.opritcamera_mode
    service_template:>
      {% if is_state ('input_select.opritcamera_mode' ,'on') %} script.camera_light_mode_on
      {% if is_state ('input_select.opritcamera_mode' ,'off') %} script.camera_light_mode_off
      {% if is_state ('input_select.opritcamera_mode' ,'auto') %} script.camera_light_mode_auto
      {% endif %}
Error:
Invalid config for [automation]: expected dictionary @ data[‘action’][0]. Got None. (See /config/configuration.yaml, line 24).
I presume that the service_template is the cause.
Thx for your help.
Remove the space between is_state and the opening bracket.
Also since around version 0.115 service_template can be replaced with service
… And add a space between the colon and the greater-than symbol
service: >
… And change the second two if to elif
Yes , solved. Thx. Damned syntax errors …
