Hi, I am trying to call service,light.turn_on
, from Developer Tools but it is not working. Template is working and verified in developer tools. It is returning correct value based on value in input_text.
Below is service details
entity_id: light.dining_room
brightness: 255
xy_color: >
{% if is_state("input_text.dining_room_scene", "Concentrate") %}
[0.459, 0.408]
{% elif is_state("input_text.dining_room_scene", "Bright") %}
[0.37, 0.372]
{% else %}
[0.37, 0.372]
{% endif %}
Error is
020-11-19 02:20:33 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.1888231184] None for dictionary value @ data['xy_color']
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 135, in handle_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 1402, in async_call
processed_data = handler.schema(service_data)
File "/usr/local/lib/python3.8/site-packages/voluptuous/validators.py", line 218, in __call__
return self._exec((Schema(val) for val in self.validators), v)
File "/usr/local/lib/python3.8/site-packages/voluptuous/validators.py", line 340, in _exec
raise e if self.msg is None else AllInvalid(self.msg, path=path)
File "/usr/local/lib/python3.8/site-packages/voluptuous/validators.py", line 336, in _exec
v = func(v)
File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 272, in __call__
return self._compiled([], data)
File "/usr/local/lib/python3.8/site-packages/voluptuous/validators.py", line 215, in _run
return self._exec(self._compiled, value, path)
File "/usr/local/lib/python3.8/site-packages/voluptuous/validators.py", line 338, in _exec
v = func(path, v)
File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 817, in validate_callable
return schema(data)
File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 594, in validate_dict
return base_validate(path, iteritems(data), out)
File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 432, in validate_mapping
raise er.MultipleInvalid(errors)
voluptuous.error.MultipleInvalid: None for dictionary value @ data['xy_color']
Thanks for your help.
