Hi, I just picked up a Aqara Smart Plug but out of the box, it has the last memory state setting to have the plug powered off when an power outage occurs (or if it’s unplugged and plugged back in the power outlet)
Question: Is it possible to set the memory state to set the device to turn back on when there is a power outage via Zigbee?
I know the application can do it based off a reddit post: https://imgur.com/a/mBz1MQB but I don’t own the Aqara gateway myself.
I don’t see this option described for your model (Aqara) but in my case (Xiaomi plug and Zigbee2mqtt), it works by sending payload via mqtt described HERE
Thanks for the link @MrUkleja . Unfortunately for this case, I am using a HUSBZB-1 to control my Zigbee devices which isn’t support by Zigbee2mqtt. I do have a CC2531 on the way but I’ll be awhile before I get that.
Just checking in to see if anyone was able to change the last power state setting. My plug is connected with deCONZ, don’t see an obvious way of changing this setting.
