Set cover tilt on window open/close
Opening a window to let air in does not work well if your covers are shut, therefore I wrote a small blueprint to automatically set the tilt after opening/closing a window.
blueprint:
  name: Window Cover Tilt Control
  domain: automation
  input:
    window_sensor:
      selector:
        entity:
          domain: binary_sensor
    cover_entity:
      selector:
        entity:
          domain: cover
    open_tilt:
      name: Open Tilt Position
      default: 100
      selector:
        number:
          min: 0
          max: 100
          unit_of_measurement: "%"
    close_tilt:
      name: Close Tilt Position
      default: 0
      selector:
        number:
          min: 0
          max: 100
    position_threshold:
      name: Cover Position Threshold
      description: Only adjust tilt if cover at least that percentage open
      default: 80
      selector:
        number:
          min: 0
          max: 100
    open_delay:
      default: 5
      selector:
        number:
          min: 0
          max: 600
          unit_of_measurement: seconds
    close_delay:
      default: 5
      selector:
        number:
          min: 0
          max: 600
mode: restart
  - platform: state
    entity_id: !input window_sensor
    to: "on"
    for: !input open_delay
  - platform: state
    to: "off"
    for: !input close_delay
condition:
  - condition: template
    value_template: "{{ state_attr(cover_entity, 'current_position') | int(0) >= position_threshold | int }}"
variables:
  cover_entity: !input cover_entity
  position_threshold: !input position_threshold
  - choose:
      - conditions:
          - condition: trigger
        sequence:
          - service: cover.set_cover_tilt_position
              entity_id: !input cover_entity
              tilt_position: !input open_tilt
      - conditions:
        sequence:
              tilt_position: !input close_tilt
Had a silly bug in it with the threshold, here’s the fix
blueprint:
  domain: automation
  input:
    window_sensor:
      selector:
        entity:
    cover_entity:
      selector:
        entity:
          domain: cover
    open_tilt:
      default: 100
      selector:
        number:
          min: 0
          max: 100
    close_tilt:
      default: 0
      selector:
        number:
          min: 0
          max: 100
    position_threshold:
      default: 80
      selector:
        number:
          min: 0
          max: 100
    open_delay:
      default: 5
      selector:
        number:
          min: 0
          max: 600
    close_delay:
      default: 5
      selector:
        number:
          min: 0
          max: 600
mode: restart
  - platform: state
    to: "on"
  - platform: state
    to: "off"
condition:
    value_template: "{{ state_attr(cover_entity, 'current_position') | int(0) <= position_threshold | int }}"
variables:
  - choose:
      - conditions:
        sequence:
      - conditions:
        sequence:
