Set 'start-on boot' to ON from CLI
hello.
While doing some tests, I’ve stopped the addons duck-DNS and NginX and also set the ‘start-on Booot’ to OFF.
After à reboot, I’ve lost the acces to lovelace ( local url:8123), But I still have acces to the CLI with ssh.
Before that change everything was working well.
Anyone knows how to set again the ‘start-on boot’ to ON from CLI?
I often find solution for my problems, but this time I’ve spent some hours looking in the net but no luck.
FYI. Home Assitant OS is installed on à Raspberry.
I’m abble to connect to another Pi to port 8080, so I do not think this is an internal LAN problem
you should be able to connect via local IP even if nginx is off
My connexion got solved rigth after cleaning browser cache.
